Vmix Web Control with Audio Slider
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Hello, I would need to control the volume levels of individual inputs with sliders via vmix web control. How can I do? Alternatively, how can I control the individual levels of each input from another computer on the same LAN network? Thank you.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Ciao vMix WebController has no slider/faders, so you have to create your own application to do that if you really need web interface. However, you could use a Midi Controller like the Akai APC Mini which has 9 faders that you can use to control audio. Here's a demo https://forums.vmix.com/....aspx?g=posts&t=9765Other midi devices may have more options to control audio. Guillaume
Ok for the controller, the problem is that the vmix computer already has a midi controller connected and if I'm wrong, Vmix managed only one controller. You have to connect a second controller to a network computer and handle the main computer with vmix. is this possible?
Thanks for your help
vMix supports multiple USB Midi controllers which do not use the same midi channel.
If you want to control audio from another computer you can use vMixUTC along with a midi controller. UTC will control vMix remotely.
