macgiver76
#1 Posted : Tuesday, May 30, 2017 4:27:03 AM(UTC)
macgiver76
Hello, I would need to control the volume levels of individual inputs with sliders via vmix web control.
How can I do?
Alternatively, how can I control the individual levels of each input from another computer on the same LAN network?
Thank you.
Speegs
#2 Posted : Tuesday, May 30, 2017 4:35:49 AM(UTC)
Speegs
Do you have an iPad?
This might be useful. It's very nice for controlling audio.
https://itunes.apple.com...surface/id978932322?mt=8
#3 Posted : Tuesday, May 30, 2017 4:41:44 AM(UTC)
Ciao
vMix WebController has no slider/faders, so you have to create your own application to do that if you really need web interface.
However, you could use a Midi Controller like the Akai APC Mini which has 9 faders that you can use to control audio.
Here's a demo https://forums.vmix.com/....aspx?g=posts&t=9765
Other midi devices may have more options to control audio.
Guillaume
macgiver76
#4 Posted : Tuesday, May 30, 2017 9:06:53 AM(UTC)
macgiver76
Ok for the controller, the problem is that the vmix computer already has a midi controller connected and if I'm wrong, Vmix managed only one controller.
You have to connect a second controller to a network computer and handle the main computer with vmix. is this possible?
Thanks for your help
#5 Posted : Tuesday, May 30, 2017 9:11:05 AM(UTC)
vMix supports multiple USB Midi controllers which do not use the same midi channel.
If you want to control audio from another computer you can use vMixUTC along with a midi controller. UTC will control vMix remotely.
