kgoodyer
#1 Posted : Saturday, May 27, 2017 7:31:35 AM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
New system.... Vmix HD
Getting Error "Invalid video data rate 2" every time I try to stream, doesn't matter what ANY of the settings are, but here are the ones I am currently using. Can't get it to stream at any irresolution, any bit-rate, any profile, level or audio codec. Just seems to be a general issue on this system, but cant think what I could have done that would cause this, error is not descriptive enough to make any rational conclusions. I have 32 RTMP streams leaving my building, some using FMLE 3.2, some using expensive hardware encoders, and some using VMIX, never had a problem like this. Any ideas.
Keith
Project 1920 x 1080 25p
External 1920 x 1080 25p via Decklink
Streaming 1024 x 576 25p
STREAMING SETTINGS
Destination: Custom RTMP Server
Input Size 1024 x 576 - LOCKED
Frame Rate 25
Video Rate 1 = 1000kbps, 1024 x 576
Audio Rate 1 - 128kbps
Video Profile : Baseline
Video Level : 3.1
Keyframe : 2 seconds
Auto Adjust : None
Audio Format : AAC
Channels Master
#2 Posted : Saturday, May 27, 2017 8:04:46 AM(UTC)
Hi
What does FFMPEG's log report?
Can you use FFMPEG on the command line ?
Hardware encoding or not ?
Are you sure your network interface is ok ?
Did you try the same with OBS (also using FFMPEG) for example ?
Guillaume
kgoodyer
#3 Posted : Saturday, May 27, 2017 5:57:04 PM(UTC)
kgoodyer
Not using FFMPEG using FMLE.
Using Adobe FMLE 3.2 simultaneously (with Main Concept AAC encoder) on same machine and setting input to VMIXvideo works perfectly. So not a hardware issue
Keith
#4 Posted : Saturday, May 27, 2017 8:05:25 PM(UTC)
In vMix Streaming Settings, click the cog icon under Quality and check that the second bitrate is not checked and set to some odd value (like zero).
This is what the error is saying, that the second bitrate is not valid or shouldn't be enabled.
