ERROR:Invalid video data rate 2
Joined: 6/16/2015(UTC) Posts: 193   Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
New system.... Vmix HD
Getting Error "Invalid video data rate 2" every time I try to stream, doesn't matter what ANY of the settings are, but here are the ones I am currently using. Can't get it to stream at any irresolution, any bit-rate, any profile, level or audio codec. Just seems to be a general issue on this system, but cant think what I could have done that would cause this, error is not descriptive enough to make any rational conclusions. I have 32 RTMP streams leaving my building, some using FMLE 3.2, some using expensive hardware encoders, and some using VMIX, never had a problem like this. Any ideas.
Keith
Project 1920 x 1080 25p External 1920 x 1080 25p via Decklink Streaming 1024 x 576 25p
STREAMING SETTINGS Destination: Custom RTMP Server Input Size 1024 x 576 - LOCKED Frame Rate 25
Video Rate 1 = 1000kbps, 1024 x 576 Audio Rate 1 - 128kbps
Video Profile : Baseline Video Level : 3.1 Keyframe : 2 seconds Auto Adjust : None Audio Format : AAC Channels Master
Hi
What does FFMPEG's log report? Can you use FFMPEG on the command line ? Hardware encoding or not ? Are you sure your network interface is ok ? Did you try the same with OBS (also using FFMPEG) for example ?
Guillaume
Not using FFMPEG using FMLE.
Using Adobe FMLE 3.2 simultaneously (with Main Concept AAC encoder) on same machine and setting input to VMIXvideo works perfectly. So not a hardware issue
Keith
In vMix Streaming Settings, click the cog icon under Quality and check that the second bitrate is not checked and set to some odd value (like zero).
This is what the error is saying, that the second bitrate is not valid or shouldn't be enabled.
Martin vMix
