GeorgeR
#1 Posted : Wednesday, May 24, 2017 6:30:01 PM(UTC)
GeorgeR
Was thanked: 30 time(s) in 28 post(s)
Hope that in the future vMix will allow streamers to select the audio source they want to use in vMixCall.
thanks 1 user thanked GeorgeR for this useful post.
Solesky on 5/24/2017(UTC)
Solesky
#2 Posted : Wednesday, May 24, 2017 7:49:37 PM(UTC)
Solesky
+1
#3 Posted : Wednesday, May 24, 2017 8:08:27 PM(UTC)
AFAIK it already does
callers can select the source of their choice, either a simple mic, or a line input fed by an external mixer for example, or theu can use a virtual mixer like VoiceMeeter to be able to switch/mix audio sources
vMix producers can use Master or Bus A or Bus B which allows to send pretty much every possible combination of audio sources to remote guests.
Maybe I did not understand well what you're expecting George, please be more specific
Guillaume
GeorgeR
#4 Posted : Wednesday, May 24, 2017 9:21:32 PM(UTC)
GeorgeR
Guillaume
DWAM,
I have two sound cards hooked up and when I use Skype I use the main sound card for my audio. I use sound card #2 for the caller audio.
#5 Posted : Thursday, May 25, 2017 9:11:36 AM(UTC)
Having 1, 2 or 10 soundcards doesn't really make a difference. It's all a matter of audio routing.
But as opposed to Skype, vMixCall doesn't need audio to be routed externally from vMix and there is no need to handle manually the mix minus. So it's much more simple!
GeorgeR
#6 Posted : Thursday, May 25, 2017 9:30:51 AM(UTC)
GeorgeR
DWAM,
two sound cards has worked for me for some time. The first sound card is internal. The second sound car connects to mt computer via USB. there both very easy to manage.
~George
#7 Posted : Thursday, May 25, 2017 9:40:00 AM(UTC)
So I don't understand what is your problem here. Could you be a little more specific? What is your exact problem considering that what you're asking for is already possible with vMix (and if I remember it well Tom already helped you setting this up some weeks ago).
GeorgeR
#8 Posted : Thursday, May 25, 2017 9:44:56 AM(UTC)
GeorgeR
Tom tried to help me out and I appreciate that. But vMixCall, as it is, doesn't work for me.
~George
mjgraves
#9 Posted : Thursday, May 25, 2017 10:36:06 AM(UTC)
mjgraves
~George
It truly is a pity that you haven't clearly stated your goal, or the problem that your trying to solve.
vMix call is a brilliant piece of work. It circumvents a tremendously complicated setup that I had to use when doing exposes on fledgling webrtc services for http://vuc.me.
I did that various ways over a period of years, from the very inception of webrtc.
We still get forced into it sometimes, like this coming week when we'll be talking to Dr Richard Stallman, who insists on only using "free software." That means no YouTube, Livestream, Ustream, etc.
Similar Topics
vMixCall audio return - doesn't work if set to Master with *only* a bus routed to Master. (vMix Call)
by spinfold 2/5/2024 5:59:49 AM(UTC)
Follow audio bus name through to vMixCall audio source (Feature Requests)
by spinfold 12/27/2023 3:55:55 AM(UTC)
vMixcall / advanced.vmixcall audio feedback (vMix Call)
by Jaime V 3/10/2021 7:41:17 PM(UTC)
VmixCall audio to support Music. Proof inside (Feature Requests)
by ayo 4/24/2020 7:53:25 PM(UTC)
Increase vMixCall audio rate for callers (Feature Requests)
by ranz 10/29/2019 1:39:25 PM(UTC)
