JohanSpijker
#1 Posted : Sunday, May 21, 2017 5:02:37 AM(UTC)
JohanSpijker
I have set my second output to Multiview.
In the settings you can choose between 4 layouts.
Is there a possibility what inputs I can see in the multiview output ?
Now the inputs are always starting at input1,......
But I want, input 11 first, then input 5, ....
#2 Posted : Sunday, May 21, 2017 5:33:09 AM(UTC)
Hi Johan
The only way is to place the inputs you want in first position. I use a layout with 8 inputs so I always put my cams first + the most important inputs that need monitoring.
I case you don't know, you can arrange the order of your inputs simply by dragging them with your mouse.
Guillaume
JohanSpijker
#3 Posted : Sunday, May 21, 2017 5:36:54 AM(UTC)
JohanSpijker
That will be the only solution, but because I'm using scripts and so, I would be easier that the multiview layout could be editable.
#4 Posted : Sunday, May 21, 2017 10:11:27 AM(UTC)
Rank:: Advanced Member
@ JohanSpijker
You can always make a "Feature Request"...
(although, IMHO, because there is a rather simple workaround, I'm not so sure it will gain much traction, but you never know, I've been known to be wrong on many occations)
Like Guillaume, I customize my 'Presets' such that my first 8 Inputs are always my "MAIN" Program Output Inputs. This works well to keep my "Shortcuts" and MIDI Controller in sync with the Program at hand.
Similar Topics
Multiview layout with 12 small and 1 large pictures (Feature Requests)
by Brano 12/19/2024 6:36:01 AM(UTC)
More multiview layouts (Feature Requests)
by robert5521 10/2/2023 9:01:42 PM(UTC)
Customize Multiview Layout (Feature Requests)
by phab 3/24/2023 12:20:45 AM(UTC)
Multiview Layout for each Fullscreen (Feature Requests)
by xun 11/23/2022 10:28:58 AM(UTC)
More flexibility for control multiview layout (Feature Requests)
by schmadam71 11/21/2020 4:40:41 AM(UTC)
Add Multiview Layout Monitoring (Feature Requests)
by Nanthyo 4/17/2020 4:09:27 AM(UTC)
Make the MultiView Layout (with Output/Preview) customizable like an Input's Multi View (Feature Requests)
by Longur 7/24/2019 8:13:55 AM(UTC)
More Multiview layout options (Feature Requests)
by curtismacd31 1/4/2018 1:43:35 PM(UTC)
