Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I have set my second output to Multiview. In the settings you can choose between 4 layouts. Is there a possibility what inputs I can see in the multiview output ? Now the inputs are always starting at input1,...... But I want, input 11 first, then input 5, ....
Hi Johan
The only way is to place the inputs you want in first position. I use a layout with 8 inputs so I always put my cams first + the most important inputs that need monitoring. I case you don't know, you can arrange the order of your inputs simply by dragging them with your mouse.
Guillaume
That will be the only solution, but because I'm using scripts and so, I would be easier that the multiview layout could be editable.
@ JohanSpijker
You can always make a "Feature Request"... (although, IMHO, because there is a rather simple workaround, I'm not so sure it will gain much traction, but you never know, I've been known to be wrong on many occations)
Like Guillaume, I customize my 'Presets' such that my first 8 Inputs are always my "MAIN" Program Output Inputs. This works well to keep my "Shortcuts" and MIDI Controller in sync with the Program at hand.
