Mathijs
#1 Posted : Thursday, May 18, 2017 2:41:19 PM(UTC)
Mathijs
As the subject, who knows a transcoding tool that can convert magicYUV to Newtek SpeedHQ?
I would like to shrink a lot of old footage down to SpeedHQ 4:2:2, but putting it all trough premiere is not really a fast workflow.
So I tried a few of transcoding tools I have installed, but none of them can export to SpeedHQ.
I did look at FFMPEG, but it seems the support they added is only for decoding?
stevespaw
#2 Posted : Thursday, May 18, 2017 10:49:06 PM(UTC)
stevespaw
Views messages in topic : 482
Was thanked: 76 time(s) in 57 post(s)
Did you try Adobe Media Encoder?
Steve
thanks 1 user thanked stevespaw for this useful post.
Mathijs on 5/19/2017(UTC)
ask
#3 Posted : Friday, May 19, 2017 4:20:22 AM(UTC)
ask
FFMPEG appears to have support for the codec. I would start there until Handrake incorporates it into its codec support library. https://en.wikipedia.org/wiki/FFmpeg
#4 Posted : Friday, May 19, 2017 4:26:19 AM(UTC)
Andrew, FFMPEG can only decode this codec, not encode
Check this : https://forums.vmix.com/...aspx?g=posts&t=10635
livepad
#5 Posted : Friday, May 19, 2017 3:35:28 PM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
There is a SpeedHQ encoder for QuickTime, so if there is also MagicYUV decoder for QuickTime - then QuickTime Player Pro on Mac would work. Apple compressor might be a good option for automated workflows.
kane
#6 Posted : Friday, May 19, 2017 4:30:43 PM(UTC)
kane
Adobe Media Encoder should be able to do this. You can setup a watch folder and have it batch process files.
Kane Peterson
NewTek
thanks 1 user thanked kane for this useful post.
Mathijs
#7 Posted : Saturday, May 20, 2017 7:11:57 AM(UTC)
Mathijs
Thanks Steve and Kane, I totally overlooked that as I normally only use it to batch render projects. I did never use it to transcode before because I used other tools for that.
It works perfectly and is the best tool for the job because it does batches, so set in the morning with a big workload and forget for the rest of the day.
I found out with this workload it is around 10% faster without cuda enabled.
Now I'm going to get a pile of disks I can re-use. The ratio for DNxHD to SpeedHQ 422 is doing around 4:1, MagicYUV to SpeedHQ even 5.5:1
