NDI
Anyone knows a transcoding tool that can convert magicYUV to Newtek SpeedHQ?
As the subject, who knows a transcoding tool that can convert magicYUV to Newtek SpeedHQ?
I would like to shrink a lot of old footage down to SpeedHQ 4:2:2, but putting it all trough premiere is not really a fast workflow. So I tried a few of transcoding tools I have installed, but none of them can export to SpeedHQ. I did look at FFMPEG, but it seems the support they added is only for decoding?
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Did you try Adobe Media Encoder?
Steve
 1 user thanked stevespaw for this useful post.
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
Mathijs wrote:As the subject, who knows a transcoding tool that can convert magicYUV to Newtek SpeedHQ?
I would like to shrink a lot of old footage down to SpeedHQ 4:2:2, but putting it all trough premiere is not really a fast workflow. So I tried a few of transcoding tools I have installed, but none of them can export to SpeedHQ. I did look at FFMPEG, but it seems the support they added is only for decoding? There is a SpeedHQ encoder for QuickTime, so if there is also MagicYUV decoder for QuickTime - then QuickTime Player Pro on Mac would work. Apple compressor might be a good option for automated workflows.
Adobe Media Encoder should be able to do this. You can setup a watch folder and have it batch process files.
Kane Peterson NewTek
 1 user thanked kane for this useful post.
Thanks Steve and Kane, I totally overlooked that as I normally only use it to batch render projects. I did never use it to transcode before because I used other tools for that. It works perfectly and is the best tool for the job because it does batches, so set in the morning with a big workload and forget for the rest of the day. I found out with this workload it is around 10% faster without cuda enabled.
Now I'm going to get a pile of disks I can re-use. The ratio for DNxHD to SpeedHQ 422 is doing around 4:1, MagicYUV to SpeedHQ even 5.5:1
NDI
