xaver
#1 Posted : Thursday, May 18, 2017 12:21:05 PM(UTC)
xaver
We use a Decklink Duo 2 for Key and Fill Input
after restart or the PC, the Key/Fill Input always is set to "None", but not to the last saved session
what's going wrong?
#2 Posted : Thursday, May 18, 2017 12:38:53 PM(UTC)
The Key Fill setting is saved when saving the vMix Preset, then it is assigned again when loading.
It will not be assigned if adding the input manually again, so using the preset is best.
xaver
#3 Posted : Thursday, May 18, 2017 1:06:07 PM(UTC)
xaver
That's what it do, if I only restart vMix
but if the PC was off for a few days, then I start vMix, call "Last" or a saved preset, the Key/Fill is set to "None"
this happens not always, but the last three times, the PC was off for more than two days.
Also if we reset the "Fill", the Key is gone
our volunteers don't know what to do, if the overlay is on and nearly the whole output is black
#4 Posted : Thursday, May 18, 2017 11:57:03 PM(UTC)
Check the source capture input being used for the Fill to see if it is not loading correctly from the preset.
xaver
#5 Posted : Sunday, May 21, 2017 2:52:25 PM(UTC)
xaver
could it be, that this happens, when Key/Fill is not present (CG machine is not sending video) when vMix starts?
