We use a Decklink Duo 2 for Key and Fill Input
after restart or the PC, the Key/Fill Input always is set to "None", but not to the last saved session what's going wrong?
Joined: 1/13/2010(UTC) Posts: 5,313  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
The Key Fill setting is saved when saving the vMix Preset, then it is assigned again when loading. It will not be assigned if adding the input manually again, so using the preset is best.
Martin vMix
That's what it do, if I only restart vMix but if the PC was off for a few days, then I start vMix, call "Last" or a saved preset, the Key/Fill is set to "None" this happens not always, but the last three times, the PC was off for more than two days. Also if we reset the "Fill", the Key is gone
our volunteers don't know what to do, if the overlay is on and nearly the whole output is black
Check the source capture input being used for the Fill to see if it is not loading correctly from the preset.
could it be, that this happens, when Key/Fill is not present (CG machine is not sending video) when vMix starts?
