Beauwulf
#1 Posted : Thursday, May 18, 2017 3:07:02 PM(UTC)
Beauwulf
Hi guys, I have a portable live setup using a laptop (Asus G751JY I7 4720-GTX980M) with a Panasonic HC-X1000 camera connected through a BlackMagic mini recorder to the Thunderbolt port on the PC. I do race venues and I'd like to add a mobile 2nd camera to the setup. Is it possible to use a wifi enabled camcorder and a wifi capture device to accomplish this? Also, what hardware would be needed? I did some searching and this particular setup info didn't seem to have been discussed. If it has, my apologizes and, could you direct me to the thread.
#2 Posted : Thursday, May 18, 2017 4:59:54 PM(UTC)
@ Beauwulf
Welcome to the forum!
Certainly a lot of discussion on this and related topics in just the last month:
https://forums.vmix.com/...aspx?g=posts&t=10723
https://forums.vmix.com/...aspx?g=posts&t=10745
https://forums.vmix.com/...aspx?g=posts&t=10781
https://forums.vmix.com/...aspx?g=posts&t=10696
https://forums.vmix.com/...aspx?g=posts&t=10687
https://forums.vmix.com/...aspx?g=posts&t=10684
If you search through the forums for "wireless" you should be able to find threads that deal with your specific query or at least put you onto the right track as to where and what you need to look into and research accordingly.
Hope that helps some.
Beauwulf on 5/20/2017(UTC)
jvphobic
#3 Posted : Thursday, May 18, 2017 5:13:44 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
You may want to look into the Teradek Bolt for wireless transmission.
thanks 1 user thanked jvphobic for this useful post.
Beauwulf
#4 Posted : Saturday, May 20, 2017 10:31:31 AM(UTC)
Beauwulf
Thanks M8! That's quite a bit out of my budget range ATM though...
#5 Posted : Saturday, May 20, 2017 12:32:10 PM(UTC)
@ Beauwulf
There are less 'Professional' (and perhaps less reliable) and cheaper options out there if you are creative and adventurous.
(not sure if you've searched the forums but I've found some more threads that are probably right up your alley)
https://forums.vmix.com/....aspx?g=posts&t=9796
https://forums.vmix.com/....aspx?g=posts&t=8406
https://forums.vmix.com/....aspx?g=posts&t=7075
https://forums.vmix.com/....aspx?g=posts&t=6257
https://forums.vmix.com/....aspx?g=posts&t=6594
vMixCall with a cell phone may also be an option if wireless internet is available.
Check out Tom Sinclair's "Streaming Idiots" Show from a few months ago:
