AgentPete
#1 Posted : Wednesday, May 17, 2017 4:07:05 PM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
Is there a simple way to customize time zones in TimerClock, i.e. to display
{0:MM/dd/yyyy h:mm tt}
minus 5 hours...?
Thanks!
#2 Posted : Thursday, May 18, 2017 5:17:45 AM(UTC)
Hi
check these pages :
https://msdn.microsoft.c.../8kb3ddd4(v=vs.110).aspx
https://msdn.microsoft.c.../bb397769(v=vs.110).aspx
Not sure it is fully implemented in vMix but using scripting there must be a way.
Guillaume
AgentPete
#3 Posted : Thursday, May 18, 2017 6:12:24 AM(UTC)
AgentPete
Thanks, Guillaume.
The "z" value is relevant, but all it seems to do is return the difference between UTC and local machine time (in my case it displays +1).
What I'm looking to do is a simple calculation... along the lines of
{0:MM/dd/yyyy (h-5):mm tt}
But the field doesn't appear to want to do any sums...
#4 Posted : Thursday, May 18, 2017 6:14:29 AM(UTC)
The 2nd link explains how to deal with time zones. (there's an option to switch to english)
AgentPete
#5 Posted : Thursday, May 18, 2017 3:30:16 PM(UTC)
AgentPete
Thanks, but this is way too complex for something that should be quite simple... I've tried pasting both the C# and the VB code in, all that happens is that the code displays :(
NYCshow
#6 Posted : Saturday, October 17, 2020 5:01:39 AM(UTC)
NYCshow
Was there ever a resolution for this? I'm looking to do the exact same thing.
Pepsi(~)
#7 Posted : Monday, October 19, 2020 3:56:08 AM(UTC)
Pepsi(~)
Netherlands
How good are you with HTML? I can share you my code, I use to provide 1 analog clock (different timezone than my vmix computer.
I run it in a web browser. And switch between various inputs. To show other times.
rcdncn
#8 Posted : Tuesday, November 16, 2021 5:00:43 PM(UTC)
rcdncn
Canada
It may not be the solution you're looking for, but if you turn on the production clock
(Settings > Options > Transition Display:Production Clock)
you can double click-it, offset the time from system time, and then select 'create input'. Then you can add it anywhere.
NOTE: You may need to remove some other Transition Display objects for the Clock to appear below the T-bar.
Do a search for "Production Clocks" in the help for more info. https://www.vmix.com/help24/
Peter1000
#9 Posted : Tuesday, November 16, 2021 6:09:37 PM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
This was solved in Doggy's Scripting for Dummies a while ago.
Code:
do while true
Dim d1 As DateTime = DateTime.Now.AddHours(3)
API.Function("SetText",Input:="clock",SelectedIndex:="0" ,Value:=d1.ToString("dd/MM/yy H:mm:ss"))
sleep(200)
loop
I had asked vMix support some time ago if time zones were supported. The time zones are not supported. A feature request would be needed.
