Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
Is there a simple way to customize time zones in TimerClock, i.e. to display
{0:MM/dd/yyyy h:mm tt}
minus 5 hours...?
Thanks!
Thanks, Guillaume.
The "z" value is relevant, but all it seems to do is return the difference between UTC and local machine time (in my case it displays +1).
What I'm looking to do is a simple calculation... along the lines of
{0:MM/dd/yyyy (h-5):mm tt}
But the field doesn't appear to want to do any sums...
The 2nd link explains how to deal with time zones. (there's an option to switch to english)
Thanks, but this is way too complex for something that should be quite simple... I've tried pasting both the C# and the VB code in, all that happens is that the code displays :(
Joined: 6/12/2020(UTC) Posts: 7  Location: New York Was thanked: 1 time(s) in 1 post(s)
Was there ever a resolution for this? I'm looking to do the exact same thing.
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
How good are you with HTML? I can share you my code, I use to provide 1 analog clock (different timezone than my vmix computer. I run it in a web browser. And switch between various inputs. To show other times.
Originally Posted by: NYCshow  Was there ever a resolution for this? I'm looking to do the exact same thing. It may not be the solution you're looking for, but if you turn on the production clock (Settings > Options > Transition Display:Production Clock)you can double click-it, offset the time from system time, and then select 'create input'. Then you can add it anywhere. NOTE: You may need to remove some other Transition Display objects for the Clock to appear below the T-bar. Do a search for "Production Clocks" in the help for more info. https://www.vmix.com/help24/
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
This was solved in Doggy's Scripting for Dummies a while ago. Code:do while true
Dim d1 As DateTime = DateTime.Now.AddHours(3)
API.Function("SetText",Input:="clock",SelectedIndex:="0" ,Value:=d1.ToString("dd/MM/yy H:mm:ss"))
sleep(200)
loop
I had asked vMix support some time ago if time zones were supported. The time zones are not supported. A feature request would be needed.
