Hardware Compatibility
decklink duo 2 1080/60p support?
can anyone confirm this support 1080/60p? i can only get up to 1080/30p
running on Akitio thunderbolt 3 box
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
when i get back home this evening will check again. is there special settings needed or updates? installed latest software from blackmagic. both ptz and camcorder having same issue. 1080/30p works fine. using ACER predator 17 laptop.
Joined: 3/7/2012(UTC) Posts: 503  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
what camera are you using.
sdi 1080p60 is pretty rare. more probable would be 720p60 or 1080i60 and reported as 30psf.
sure you have this on your 3g sdi ...
stefan
i sent this back already. my laptop already has 4 USB3 Port. im better of adding 4port usb3 pcie card for additional usb capture card than Blackmagic headache
