hbb
#1 Posted : Friday, May 12, 2017 2:48:40 PM(UTC)
hbb
can anyone confirm this support 1080/60p? i can only get up to 1080/30p
running on Akitio thunderbolt 3 box
#2 Posted : Friday, May 12, 2017 2:52:50 PM(UTC)
yes
hbb
#3 Posted : Saturday, May 13, 2017 9:02:16 AM(UTC)
hbb
when i get back home this evening will check again. is there special settings needed or updates? installed latest software from blackmagic. both ptz and camcorder having same issue. 1080/30p works fine.
using ACER predator 17 laptop.
#4 Posted : Sunday, May 14, 2017 9:14:09 AM(UTC)
Might be a converter problem. Did you check this topic ? https://forums.vmix.com/....aspx?g=posts&t=9616
Also make sure you're using 3G-SDI cables...
When you plug your cams to a monitor, what does it report for signal type?
h2video.nl
#5 Posted : Tuesday, May 16, 2017 2:57:17 PM(UTC)
h2video.nl
what camera are you using.
sdi 1080p60 is pretty rare. more probable would be 720p60 or 1080i60 and reported as 30psf.
sure you have this on your 3g sdi ...
stefan
hbb
#6 Posted : Thursday, May 18, 2017 8:23:12 PM(UTC)
hbb
i sent this back already. my laptop already has 4 USB3 Port. im better of adding 4port usb3 pcie card for additional usb capture card than Blackmagic headache
