Audio Latency Dropouts only when VMIX window active
I'm running Ableton Live 9 audio software, playing audio thru it VST synth and a slew of audio. Ableton is awesome on it's own, Vmix is awesome... but for some reason, when I click on Vmix as the active window to make changes, my audio goes haywire.
To be honest, I do have a complicated setup (MOTU 828 mkii firewire audio interface, multiple cameras etc)... but it drives me crazy because sometimes the software works just fine even when active... then I go to adjust something and vmix becomes my audio's nemesis. I change the fps from 30 to 60, or restart... and maybe this time it's ok again, maybe not.
I can repeat and reset the issue, but just can't put my finger on one specific setting or parameter that makes it reliable.
I've tried 30fps, 60fps, different audio options, internal mixer on and off, heck I think i've checked on and off every box one by one to see if I could isolate it. I even recently upgraded from windows 7 to windows 10 (both 64 bit) to see if it was a driver issue of some sort that might need updating.
Help! I love vmix, and would love to abandon both xsplit and obs for my partnered twitch program... the MIDI shortcuts alone are worth $300 to me, but I need to get this resolved before I can stream with confidence.
Thanks!
CKurtis
Hi
give us more details and useful info
hardware specs? asio? number and type of cameras? number of usb devices? etc...
we are not magicians!
ZT systems computer i7-2600 @3.4 16gb ram Windows 10 Home (but it did it on Windows 7 home too)
Motu asio (multi channel) firewire adapter 828 mk ii (it's 18 in and 10 out I believe)
3 logitech 920's and 1 922. (the problems happen even if I have a completely empty load of vmix, no cameras, scenes, inputs)
a wireless microsoft keyboard mouse combo, as well as an attached logitech keyboard and trackball. Various musical keyboards also connected via usb.
Nvidia GeForce GT 740 sc display (4 gig) adapter with a samsung U28E510 at 2560 x 1440, and a Seki se42um tv running at 4K
Samsung SSD 850 EVO 500GB Drive
Let me know what other information you need. I know you aren't magicians, I just didn't know where to start. =o)
Chris
I ran a program called latencyMon. runs fine if the vmix window isn't selected. After selected it sputters... this is the output from it. I'm not sure if this is helpful at all?
Thanks again,
Chris
_________________________________________________________________________________________________________ CONCLUSION _________________________________________________________________________________________________________ Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates. LatencyMon has been analyzing your system for 0:01:19 (h:mm:ss) on all processors.
_________________________________________________________________________________________________________ SYSTEM INFORMATION _________________________________________________________________________________________________________ Computer name: SOLIDBAMBOO OS version: Windows 10 , 10.0, build: 15063 (x64) Hardware: H67MA-USB3-B3, Gigabyte Technology Co., Ltd. CPU: GenuineIntel Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz Logical processors: 8 Processor groups: 1 RAM: 16367 MB total
_________________________________________________________________________________________________________ CPU SPEED _________________________________________________________________________________________________________ Reported CPU speed: 3392 MHz Measured CPU speed: 1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
_________________________________________________________________________________________________________ MEASURED INTERRUPT TO USER PROCESS LATENCIES _________________________________________________________________________________________________________ The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 2136.869527 Average measured interrupt to process latency (µs): 4.906434
Highest measured interrupt to DPC latency (µs): 2132.643482 Average measured interrupt to DPC latency (µs): 2.764337
_________________________________________________________________________________________________________ REPORTED ISRs _________________________________________________________________________________________________________ Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 228.667748 Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.755488 Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 1.351381
ISR count (execution time <250 µs): 2448548 ISR count (execution time 250-500 µs): 0 ISR count (execution time 500-999 µs): 0 ISR count (execution time 1000-1999 µs): 0 ISR count (execution time 2000-3999 µs): 0 ISR count (execution time >=4000 µs): 0
_________________________________________________________________________________________________________ REPORTED DPCs _________________________________________________________________________________________________________ DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 644.211675 Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 1.174375 Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 2.140579
DPC count (execution time <250 µs): 1809682 DPC count (execution time 250-500 µs): 0 DPC count (execution time 500-999 µs): 584 DPC count (execution time 1000-1999 µs): 0 DPC count (execution time 2000-3999 µs): 0 DPC count (execution time >=4000 µs): 0
_________________________________________________________________________________________________________ REPORTED HARD PAGEFAULTS _________________________________________________________________________________________________________ Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count: none
Total number of hard pagefaults 0 Hard pagefault count of hardest hit process: 0 Highest hard pagefault resolution time (µs): 0.0 Total time spent in hard pagefaults (%): 0.0 Number of processes hit: 0
_________________________________________________________________________________________________________ PER CPU DATA _________________________________________________________________________________________________________ CPU 0 Interrupt cycle time (s): 16.050934 CPU 0 ISR highest execution time (µs): 228.667748 CPU 0 ISR total execution time (s): 8.401512 CPU 0 ISR count: 2414874 CPU 0 DPC highest execution time (µs): 424.007370 CPU 0 DPC total execution time (s): 9.613334 CPU 0 DPC count: 1657151 _________________________________________________________________________________________________________ CPU 1 Interrupt cycle time (s): 1.931311 CPU 1 ISR highest execution time (µs): 17.505307 CPU 1 ISR total execution time (s): 0.036020 CPU 1 ISR count: 11033 CPU 1 DPC highest execution time (µs): 414.798054 CPU 1 DPC total execution time (s): 1.548624 CPU 1 DPC count: 31208 _________________________________________________________________________________________________________ CPU 2 Interrupt cycle time (s): 1.961458 CPU 2 ISR highest execution time (µs): 24.048644 CPU 2 ISR total execution time (s): 0.047001 CPU 2 ISR count: 10804 CPU 2 DPC highest execution time (µs): 644.211675 CPU 2 DPC total execution time (s): 1.552537 CPU 2 DPC count: 43548 _________________________________________________________________________________________________________ CPU 3 Interrupt cycle time (s): 0.645178 CPU 3 ISR highest execution time (µs): 38.483491 CPU 3 ISR total execution time (s): 0.025320 CPU 3 ISR count: 5368 CPU 3 DPC highest execution time (µs): 377.823113 CPU 3 DPC total execution time (s): 0.210709 CPU 3 DPC count: 16670 _________________________________________________________________________________________________________ CPU 4 Interrupt cycle time (s): 1.458941 CPU 4 ISR highest execution time (µs): 37.638856 CPU 4 ISR total execution time (s): 0.031613 CPU 4 ISR count: 5325 CPU 4 DPC highest execution time (µs): 442.800118 CPU 4 DPC total execution time (s): 0.353044 CPU 4 DPC count: 28447 _________________________________________________________________________________________________________ CPU 5 Interrupt cycle time (s): 0.388017 CPU 5 ISR highest execution time (µs): 17.885613 CPU 5 ISR total execution time (s): 0.007162 CPU 5 ISR count: 1073 CPU 5 DPC highest execution time (µs): 120.939858 CPU 5 DPC total execution time (s): 0.039643 CPU 5 DPC count: 8619 _________________________________________________________________________________________________________ CPU 6 Interrupt cycle time (s): 0.415912 CPU 6 ISR highest execution time (µs): 32.868514 CPU 6 ISR total execution time (s): 0.000485 CPU 6 ISR count: 63 CPU 6 DPC highest execution time (µs): 100.924528 CPU 6 DPC total execution time (s): 0.070442 CPU 6 DPC count: 9614 _________________________________________________________________________________________________________ CPU 7 Interrupt cycle time (s): 0.492416 CPU 7 ISR highest execution time (µs): 7.645342 CPU 7 ISR total execution time (s): 0.000048 CPU 7 ISR count: 8 CPU 7 DPC highest execution time (µs): 78.782724 CPU 7 DPC total execution time (s): 0.153483 CPU 7 DPC count: 15009 _________________________________________________________________________________________________________
increase your latency value for asio... for a start... and check
your graphics card is not ideal for vMix but I'm pretty sure your issue is mainly asio related
high latency makes it difficult for me to play live keyboards.
the latency is fine, even when I'm changing all kinds of scenes and cameras via midi hotkeys, not a glitch
once I choose vmix as the active window... no amount of buffers helps. I've done great with it set as low as 64 with no glitches with vmix not chosen, and as high as 1024 with glitches when vmix is chosen.
I'll try another graphics card if you think that's the issue... just seems strange that it's only when it's an active chosen window. no other programs or windows open have this effect.
Chris
I understood what your problem is... But the cause is not vMix, it's your audio setup. Quote:Your system appears to be having trouble handling real-time audio and other tasks. I did not ask to go to high latency, but to increase it for a few ms. I'm a guitarist playing on asio drivers, I know the effect that changing latency from 7 ms to 10/12 ms can have on a system. I also know which values allow to play. Try what I say, just to see if I'm right. If you're not happy with it, then I guess you have to use 2 computers: one for audio, one for video.
so the fact that I can run 1024 buffer, and still have pops when I chose vmix as the active window,
and the fact that I can go as good as 64 buffer, and have no pops when running vmix as long as it's not the active window.
and the part where I can run all kinds of other programs, make them the active window, and not encounter this problem...
you don't think vmix is related to this issue?
it only has problems dealing with real time audio when vmix is the active window, the workaround I'll likely use, if need be, is to use vmix but never touch the program directly... and program a zillion hotkeys.
how about we see if perhaps vmix is indeed the issue, instead of buying another computer? is that so crazy?
Chris
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Is vMix, for sure, running on the Nvidia GPU?
The card is definitely a minimum card.
Steve
Also running at 4k can be an issue with such a minimum card. What about running the display at 1920x1080? same issue?
Steve
it's the only card I have and it's running a two monitor's, one of which is a 4k. Runs like a dream, until vmix is chosen.
I'll try different resolutions... but the fact that it only happens when it's active is what has me confused. gimme a minute
I scaled them both back to 1920x1080. Same issue.
You have onboard video on this motherboard are you sure vMix is not using the Intel?
Steve
Settings- performance
In use: NVIDIA GeForce GT 740 (the choices are default and two identical looking NVIDIA GeForce GT 740 choices)
low latency is not set
neither is enable optimus graphics compat
output format UYVY renderer EVR skip 0 priority normal
Everything under that is checked except memory and read lock.
I will add this wrinkle... if I make a change like fps, or something that requires vmix to restart...if I stay on vmix as the active window... I don't get the drop outs. if I chose another window, then go back to vmix.. the drop outs happen again.
Are you using hardware encoding, and have you tried switching it off? In case of my x99 this was one of the many tweaks I did to get rid of audio dropouts.
 1 user thanked Ittaidv for this useful post.
hardware encoding where? in vmix? in ableton? the nvidia ap?
thanks in advance!
Hardware encoding in vmix: check in your streaming and recording settings if the box is ticked.
@ Ittaidv
I believe hardware encoding is supported with GTX 750 and above. As far as I am concerned, NVidia x10 to x40 series cards are entry level cards anyways.
But it may be a mute point in ckurtis' case as I am inclined to think it is a software/driver incompatibility issue somewhere along the line. Just my thoughts.
Tried the hardware encoding off and on both in stream and record settings. the 740 with 4gig has been easily handling 2-3 monitors at up to 4k resolutions, but if you guys think it's the issue I'll replace it.
The big question is then, what do you think will work? something to power a minimum of 3 monitors, and will fit into one slot? I'll get it tomorrow if that's the weak link here.
Nothing is more frustrating that being so close to perfection, but you just can't click one window or it all goes to hell.
I'm going to likely ditch my firewire card and my usb3.0 card for a combo card so I can fit a double space graphics card in my tower. So I'm open to two space cards. Any thoughts on these 1060's or 960's? http://a.co/bVvKSaaor this one? http://a.co/hxf4tnXwill they be supported by vmix if I encounter the same problem? Thanks
