Feature Requests
Bug? Triggers get messed up when input numbers change when editing
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 17 times Was thanked: 17 time(s) in 14 post(s)
I've noticed that if I create a set of triggers which refer to specific inputs - lets say input #10 for the sake of illustration, everything is OK until I delete input #6.
The triggers continue working normally, but if I go to edit them, although the input displays in the list correctly, when you click on a list item, it puts the wrong input in the edit area - which means you have to go and find the correct input again. It is as if the triggers will now refer to what was input #11 instead of #9.
Its a minor thing - but irritating if you have to edit several triggers.
Many thanks for an awesome product!
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
This is normal behaviour Giles
It's better not to use input numbers, but rather GUIDs or Names.
Guillaume
Joined: 5/20/2015(UTC) Posts: 493   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
Agreed with Guillaume. Dont rely on input numbers, but instead the GUID or name.
Hi DWAM / Jens Thank you for your responses. I'm not sure we are talking about the same thing, as I see no way to use the GUID instead of the input numbers. Please see this clip: All the best, Giles.
Hi Giles,
Seems like you definitely found a bug right there!
Yep, it seems problem was solved for shortcuts but not triggers indeed.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
+1
I can only confirm the findings from Giles.
Feature Requests
