StepBackInTime_TV
#1 Posted : Monday, May 15, 2017 6:01:07 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
I've noticed that if I create a set of triggers which refer to specific inputs - lets say input #10 for the sake of illustration, everything is OK until I delete input #6.
The triggers continue working normally, but if I go to edit them, although the input displays in the list correctly, when you click on a list item, it puts the wrong input in the edit area - which means you have to go and find the correct input again. It is as if the triggers will now refer to what was input #11 instead of #9.
Its a minor thing - but irritating if you have to edit several triggers.
Many thanks for an awesome product!
#2 Posted : Monday, May 15, 2017 6:09:29 AM(UTC)
Views messages in topic : 2,721
This is normal behaviour Giles
It's better not to use input numbers, but rather GUIDs or Names.
Guillaume
stigaard
#3 Posted : Monday, May 15, 2017 7:07:56 AM(UTC)
stigaard
Denmark
Agreed with Guillaume. Dont rely on input numbers, but instead the GUID or name.
StepBackInTime_TV
#4 Posted : Monday, May 15, 2017 2:23:02 PM(UTC)
StepBackInTime_TV
Hi DWAM / Jens
Thank you for your responses. I'm not sure we are talking about the same thing, as I see no way to use the GUID instead of the input numbers.
Please see this clip:
All the best,
Giles.
stigaard
#5 Posted : Monday, May 15, 2017 2:27:41 PM(UTC)
stigaard
Denmark
Hi Giles,
Seems like you definitely found a bug right there!
#6 Posted : Monday, May 15, 2017 5:12:41 PM(UTC)
Yep, it seems problem was solved for shortcuts but not triggers indeed.
Amokka
#7 Posted : Monday, May 15, 2017 5:43:02 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
+1
I can only confirm the findings from Giles.
