vMix 2011 Beta 5 Released (Updated 21 May 2011)
Joined: 1/13/2010(UTC) Posts: 5,371  Location: Gold Coast, Australia Was thanked: 4794 time(s) in 1646 post(s)
Minor update has been posted to the Download page.
* Fixes issue with automatic restart of recordings.
Another update which fixes an issue with XP has been posted to the Download page.
* Fixes issue when fading under XP.
Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hello AUDIO problems and not a video image is fixed. BETA VMix2011
1 - I have always problems AUDIO try all options. Camera was not live but video clips saved to PC, audio mixer selected.
2 - I want to keep a permanent video image video background, but to select another camera or short video skips or change automatically. (Quick Play [1] and [2] Loop removes the main backgraound important)
Martin I need an option for a fund or permanent video and audio.
thanks always super job all
(promoting the software in Spanish)
1. What is the audio problem? What source does not have audio?
2. Keep the background as the active input. Then click O1 or O2 to change the camera.
I downloaded your software, and created a show looked and worked great together with FMLE. After testing several settings, I could not start the show again because there was still something active. After I restarted my computer vMix did not start giving an error D3DStartup? I reinstalled vMix but no result. Still the error message.
Click the option on the error message to Send Error Report, so we can investigate further.
I did sent you the error report. After restarting my computer again for some other reason, vMix started as normal. I don't understand but I am happy.
GRACIAS BAJANDO , SE VE MEJOR
Thank you very much for a great product. I am using it now for several moth and it still gives me pleasure. But… I have downloaded your update to vmix2011beta3.exe. I was happily surprised to see that with a flash file I got a volume mixer. After trying to stream my result, with Adobe Flash Media Live Encoder 3.1 the FMLE crashed. After stopping vMix to stream and restarted the FMLE, FMLE started as usual. After I pushed start streaming (in vMix), FMLE crashed immediately. I am returning to beta2 version and wait for a useful update. Maybe You can try to output the audio as well, I have read the topics about the audio problems, and there was no solution that worked for me, I would like to choose in FMLE the video source “vMix Capture” and in the Audio device alse “vMix Capture” then your program would be perfect to me. Pieter van Diest www.imcanederland.nl
We have been using vMix for almost a year now to stream our church services and i must say it's a great piece of software! Thank you! However, when using the latest beta version (3), we encountered an error with USTREAM Producer under windows 7 32bit. It starts up and then immediately after loading all modules, it crashes. We switched back to beta 2 and all is good now.
Happy Easter! Radu
Pieter,
vMix streaming must be started BEFORE running Adobe Flash Media Live Encoder otherwise FMLE will not know what resolution to use. The same issue should occur on Beta 2 as well as this functionality has not been changed.
What resolution/frame rate are you using for External Output in vMix?
Radu,
I have discovered a bug with vMix and USTREAM Producer, this will be fixed in the next beta.
I have a problem with the audio. 1. Variance is picture and sound. 2. How to work together with audio from an external source and video file?
