#1 Posted : Friday, February 4, 2011 9:17:22 AM(UTC)
Was thanked: 4765 time(s) in 1636 post(s)
vMix 2011 Beta 5 has been released.
Full details available on the Download page:
http://www.vmix.com.au/download.aspx
Please report any bugs or issues in this thread.
Enjoy!
#2 Posted : Saturday, February 5, 2011 1:59:08 AM(UTC)
Minor update has been posted to the Download page.
* Fixes issue with automatic restart of recordings.
#3 Posted : Sunday, February 6, 2011 3:05:26 AM(UTC)
Another update which fixes an issue with XP has been posted to the Download page.
* Fixes issue when fading under XP.
ELCHAPIN
#4 Posted : Tuesday, February 8, 2011 12:53:28 PM(UTC)
ELCHAPIN
Hello
AUDIO problems and not a video image is fixed. BETA VMix2011
1 - I have always problems AUDIO
try all options.
Camera was not live but video clips
saved to PC, audio mixer selected.
2 - I want to keep a permanent video image
video background, but to select another camera or short video
skips or change automatically.
(Quick Play [1] and [2] Loop removes the main backgraound important)
I need an option for a fund or permanent video and audio.
thanks always
super job all
(promoting the software in Spanish)
#5 Posted : Wednesday, February 9, 2011 1:13:49 AM(UTC)
1. What is the audio problem? What source does not have audio?
2. Keep the background as the active input. Then click O1 or O2 to change the camera.
pieter van diest
#6 Posted : Wednesday, February 9, 2011 10:07:55 AM(UTC)
pieter van diest
I downloaded your software, and created a show looked and worked great together with FMLE.
After testing several settings, I could not start the show again because there was still something active.
After I restarted my computer vMix did not start giving an error D3DStartup?
I reinstalled vMix but no result. Still the error message.
#7 Posted : Wednesday, February 9, 2011 10:23:01 AM(UTC)
Click the option on the error message to Send Error Report, so we can investigate further.
pieter van diest
#8 Posted : Wednesday, February 9, 2011 1:20:06 PM(UTC)
pieter van diest
I did sent you the error report.
After restarting my computer again for some other reason, vMix started as normal.
I don't understand but I am happy.
#9 Posted : Wednesday, March 9, 2011 5:39:22 AM(UTC)
vMix Beta 3 has been released to the Download page.
See http://www.vmix.com.au/download.aspx for full details.
ELCHAPIN on 3/10/2011(UTC)
ELCHAPIN
#10 Posted : Thursday, March 10, 2011 7:43:51 PM(UTC)
ELCHAPIN
GRACIAS BAJANDO , SE VE MEJOR
pieter van diest
#11 Posted : Wednesday, April 20, 2011 7:10:06 AM(UTC)
pieter van diest
Thank you very much for a great product. I am using it now for several moth and it still gives me pleasure.
But…
I have downloaded your update to vmix2011beta3.exe.
I was happily surprised to see that with a flash file I got a volume mixer.
After trying to stream my result, with Adobe Flash Media Live Encoder 3.1 the FMLE crashed. After stopping vMix to stream and restarted the FMLE, FMLE started as usual. After I pushed start streaming (in vMix), FMLE crashed immediately.
I am returning to beta2 version and wait for a useful update.
Maybe You can try to output the audio as well, I have read the topics about the audio problems, and there was no solution that worked for me, I would like to choose in FMLE the video source “vMix Capture” and in the Audio device alse “vMix Capture” then your program would be perfect to me.
Pieter van Diest
www.imcanederland.nl
radu2001
#12 Posted : Saturday, April 23, 2011 2:57:55 AM(UTC)
radu2001
We have been using vMix for almost a year now to stream our church services and i must say it's a great piece of software! Thank you!
However, when using the latest beta version (3), we encountered an error with USTREAM Producer under windows 7 32bit. It starts up and then immediately after loading all modules, it crashes. We switched back to beta 2 and all is good now.
Happy Easter!
Radu
#13 Posted : Saturday, April 23, 2011 7:23:03 AM(UTC)
Pieter,
vMix streaming must be started BEFORE running Adobe Flash Media Live Encoder otherwise FMLE will not know what resolution to use.
The same issue should occur on Beta 2 as well as this functionality has not been changed.
What resolution/frame rate are you using for External Output in vMix?
#14 Posted : Saturday, April 23, 2011 8:56:22 AM(UTC)
Radu,
I have discovered a bug with vMix and USTREAM Producer, this will be fixed in the next beta.
radu2001
#15 Posted : Saturday, April 23, 2011 11:45:57 AM(UTC)
radu2001
Thank you!
Radu
darakchiev
#16 Posted : Tuesday, May 31, 2011 6:34:46 AM(UTC)
darakchiev
I have a problem with the audio.
1. Variance is picture and sound.
2. How to work together with audio from an external source and video file?
