Simultaneously record 4 SDI signals.
I have a demand.
Record 4-player game first view video.
Simultaneous acquisition of 4 SDI sources to record video (HDMI capture computer signals, enter the BMD (AJA) capture card 1080P / 60fps).
Can not find the right software!
Can you recommend it?
Hi vMix can do this using MultiCorder http://www.vmix.com/help19/MultiCorder.htmlGuillaume Edit: Oh maybe I misunderstood your request. If you want all 4 sources side by side, just use multiview feature. You can use up to 10 sources in a single view.
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
heres 1 4k 60fps and 3 1080p 60fps with Vmix and a Kona 4 and a Kona 3G
 1 user thanked hellokitty for this useful post.
DWAM wrote:Hi vMix can do this using MultiCorder http://www.vmix.com/help19/MultiCorder.htmlGuillaume Edit: Oh maybe I misunderstood your request. If you want all 4 sources side by side, just use multiview feature. You can use up to 10 sources in a single view. 4 SDI into VMIX, while recording 4 SDI signal video (including audio included).
That's exactly what the multicorder is made for
