lem
#1 Posted : Wednesday, May 10, 2017 2:17:11 AM(UTC)
lem
I have a demand.
Record 4-player game first view video.
Simultaneous acquisition of 4 SDI sources to record video (HDMI capture computer signals, enter the BMD (AJA) capture card 1080P / 60fps).
Can not find the right software!
Can you recommend it?
#2 Posted : Wednesday, May 10, 2017 2:38:52 AM(UTC)
Hi
vMix can do this using MultiCorder
http://www.vmix.com/help19/MultiCorder.html
Guillaume
Edit: Oh maybe I misunderstood your request. If you want all 4 sources side by side, just use multiview feature. You can use up to 10 sources in a single view.
hellokitty
#3 Posted : Wednesday, May 10, 2017 3:07:18 AM(UTC)
hellokitty
heres 1 4k 60fps and 3 1080p 60fps with Vmix and a Kona 4 and a Kona 3G
thanks 1 user thanked hellokitty for this useful post.
lem on 5/11/2017(UTC)
lem
#4 Posted : Thursday, May 11, 2017 8:31:10 AM(UTC)
lem
谢谢!
lem
#5 Posted : Thursday, May 11, 2017 8:34:28 AM(UTC)
lem
DWAM wrote:
Hi
Guillaume
4 SDI into VMIX, while recording 4 SDI signal video (including audio included).
#6 Posted : Thursday, May 11, 2017 8:41:44 AM(UTC)
That's exactly what the multicorder is made for
