Good evening, can I use two vmix sessions on the same pc? I also have two licenses in case they need to serve thank you regards Ettore
Hi Ettore
Although it is not recommended, you can do it. Just go to settings, tick the "show advanced settings" option, go to "options" tab and tick "allow multiple instances"
Guillaume
Perfect the two sessions opens it in a stream stream session to a wowza server while with the other i have to stream on facebook. When I launch streams to facebook I get the following error: "Capture Device is still in use, close any open programs and try again" what should I do? thank you
try NDI input of the camera in the second session in first session make sure you have External output/ndi cameras checked
You can stream to Wowza and FB at the same time with a single instance of vMix btw...
And if you want to control independently each of your streams, I recommend to use vMix for the first stream and use External Out to feed another encoder like OBS for example
I could use what i tell but i need a different output from the first session, i wowza server i have to send a content on facebook a different content always using the same cameras
