mixsystem
#1 Posted : Wednesday, May 10, 2017 12:57:53 PM(UTC)
mixsystem
Good evening, can I use two vmix sessions on the same pc? I also have two licenses in case they need to serve
thank you
regards
Ettore
#2 Posted : Wednesday, May 10, 2017 1:14:11 PM(UTC)
Hi Ettore
Although it is not recommended, you can do it. Just go to settings, tick the "show advanced settings" option, go to "options" tab and tick "allow multiple instances"
Guillaume
mixsystem
#3 Posted : Wednesday, May 10, 2017 1:21:26 PM(UTC)
mixsystem
Perfect the two sessions opens it in a stream stream session to a wowza server while with the other i have to stream on facebook. When I launch streams to facebook I get the following error: "Capture Device is still in use, close any open programs and try again"
what should I do?
thank you
#4 Posted : Wednesday, May 10, 2017 1:30:42 PM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
try NDI input of the camera in the second session
in first session make sure you have External output/ndi cameras checked
#5 Posted : Wednesday, May 10, 2017 1:48:47 PM(UTC)
You can stream to Wowza and FB at the same time with a single instance of vMix btw...
#6 Posted : Wednesday, May 10, 2017 1:50:39 PM(UTC)
And if you want to control independently each of your streams, I recommend to use vMix for the first stream and use External Out to feed another encoder like OBS for example
mixsystem
#7 Posted : Thursday, May 11, 2017 3:26:56 AM(UTC)
mixsystem
I could use what i tell but i need a different output from the first session, i wowza server i have to send a content on facebook a different content always using the same cameras
#8 Posted : Thursday, May 11, 2017 3:35:21 AM(UTC)
Then simply use External2 Out going to your 2nd encoder.
There are solutions for "sub-switching" specifically for External2 at the same time as for PGM (with a single instance):
- in this video I demonstrate how to do it with vMixUTC:
https://forums.vmix.com/...ts&m=34998#post34998
- in this one, I use a Midi Controller:
https://forums.vmix.com/....aspx?g=posts&t=9765 (topic)
(demo video)
