paulmeheux
#1 Posted : Tuesday, March 12, 2013 10:17:38 AM(UTC)
paulmeheux
Hi, is there a way to be able to change slides within vmix via acue system or slide advancer?
I would really like to use the program on live events with presenters being able to control the slides
Thank you
jwolthuis
#2 Posted : Tuesday, March 12, 2013 11:12:37 AM(UTC)
jwolthuis
Was thanked: 9 time(s) in 6 post(s)
Thank you
You can change slides via a web browser. If the presenter has a smart device (laptop, iPad, smartphone, Surface, etc), they can bring up the Web Interface in their browser.
To enable Slide Advance, you would add a Shortcut with Function "NextPicture" and Input "MySlides" (specify either your PowerPoint or your folder containing images). Additional shortcuts can be added for "PreviousPicture", "FadeToBlack", or "Restart".
Jon
thanks 1 user thanked jwolthuis for this useful post.
paulmeheux on 6/20/2013(UTC)
paulmeheux
#3 Posted : Tuesday, March 12, 2013 11:32:15 AM(UTC)
paulmeheux
Thanks Jon,
but I really need them to be able to control it remotely while they walk around with a small slide advancer.
is this possible?
Grimble
#4 Posted : Tuesday, March 12, 2013 12:14:21 PM(UTC)
Grimble
If your slide advancer can emulate a keypress, you can use setup a shortcut in vMix directly, or use something like autohotkey to trigger it via the web interface from another workstation.
paulmeheux
#5 Posted : Tuesday, March 12, 2013 1:24:21 PM(UTC)
paulmeheux
Thanks Grimble,
The cue system i use is a USB connection and is supposed to emulate the keys as you say.
I will have another play and see if it works. Are there any settings which may prevent it from working?
#6 Posted : Tuesday, March 12, 2013 10:27:33 PM(UTC)
Was thanked: 4660 time(s) in 1606 post(s)
Most slide advancers send PageUp and PageDown as the keys.
These can be configured in vMix using the "PageUp" and "Next" shortcut key options.
Grimble
#7 Posted : Wednesday, March 13, 2013 6:36:28 AM(UTC)
Grimble
I _think_ if the vMix window doesn't have focus, it won't get the keypress. In this case, you can set up AutoHotkey to send it through, I think, regardless of what window has focus - use the ControlSend function - http://www.autohotkey.co...commands/ControlSend.htm
