Trying to record in aspect ratio 4:3
Hello. I downloaded the recent version as trail. everything is fine. until I want edit the recording. it seem the final recording is 5:4 aspect ratio format.how to change it 4:3 format?. (SD - 720x576 - mpg2 - frame rate pal 25p)
thx
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
720x576 is the standard pixel size for Standard Def PAL video in digital form, for both 4:3 and 16:9 aspect ratios. Neither aspect ratio uses "square pixels", both are anamorphic, although 16:9 more so than 4:3. In your edit software you need to tell it what aspect ratio to use for this footage. In Adobe Premiere, for example, you use the Interpret-As function (under Clip->Modify) to use 720x576 clips as either standard or widescreen aspect ratio.
