hak
#1 Posted : Tuesday, May 9, 2017 2:10:28 AM(UTC)
hak
Hello.
I downloaded the recent version as trail. everything is fine. until I want edit the recording. it seem the final recording is 5:4 aspect ratio format.how to change it 4:3 format?.
(SD - 720x576 - mpg2 - frame rate pal 25p)
thx
zenvideo
#2 Posted : Tuesday, May 9, 2017 3:11:48 AM(UTC)
zenvideo
720x576 is the standard pixel size for Standard Def PAL video in digital form, for both 4:3 and 16:9 aspect ratios. Neither aspect ratio uses "square pixels", both are anamorphic, although 16:9 more so than 4:3. In your edit software you need to tell it what aspect ratio to use for this footage. In Adobe Premiere, for example, you use the Interpret-As function (under Clip->Modify) to use 720x576 clips as either standard or widescreen aspect ratio.
hak
#3 Posted : Tuesday, May 9, 2017 6:15:25 AM(UTC)
hak
thanks
