JohanSpijker
#1 Posted : Monday, May 8, 2017 5:19:01 PM(UTC)
JohanSpijker
Would it be possible to send and UDP (or http) command out of VMIX to an external device ?
Maybe in a script ?
#2 Posted : Monday, May 8, 2017 5:37:44 PM(UTC)
Vb.net scripts should allow this, but it's difficult to confirm with so little information
JohanSpijker
#3 Posted : Monday, May 8, 2017 6:07:25 PM(UTC)
JohanSpijker
I want to send a string to an external device like a brightsign player by udp (or tcp-client) commands over the network.
the brightsignplayer listens on a specific port.
so I hoped there was a vb.net command/script like this:
UDPClient.Connect("10.0.0.141", 11000)
UDPClient.Send("play")
smudge1977
#4 Posted : Thursday, November 8, 2018 8:40:08 AM(UTC)
smudge1977
Was thanked: 4 time(s) in 1 post(s)
Did you get a solution please?
UDP you woud just send the command btw.
I want to send a telnet command on a custom port but i can not define a variable of type tcpclient which is at the route of any examples i can find
Keith
