3rd Party Software and Development
scripting: send UDP command to external device
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hello, Would it be possible to send and UDP (or http) command out of VMIX to an external device ? Maybe in a script ?
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Vb.net scripts should allow this, but it's difficult to confirm with so little information
I want to send a string to an external device like a brightsign player by udp (or tcp-client) commands over the network. the brightsignplayer listens on a specific port.
so I hoped there was a vb.net command/script like this:
UDPClient.Connect("10.0.0.141", 11000) UDPClient.Send("play")
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
Originally Posted by: JohanSpijker  I want to send a string to an external device like a brightsign player by udp (or tcp-client) commands over the network. the brightsignplayer listens on a specific port.
Did you get a solution please? UDP you woud just send the command btw. I want to send a telnet command on a custom port but i can not define a variable of type tcpclient which is at the route of any examples i can find Thanks Keith
