MegaJos
#1 Posted : Thursday, April 27, 2017 2:28:13 PM(UTC)
MegaJos
Anyone else witnessing that the XAML-product from Blend loses its flow in vMix?
I've made a smooth movement (a moving picture) in Blend that becomes very choppy when imported into vMix. The only thing that I can think of is that it´s made in VB 4.0 instead of vMix-supported 3.5.
#2 Posted : Thursday, April 27, 2017 4:17:57 PM(UTC)
@ MegaJos
Which version of MS Blend were you using?
My understanding is that some of the newer features (commands??) of Visual Studio 2015 are not supported in vMix as per this post here:
https://forums.vmix.com/....aspx?g=posts&t=6445
MegaJos
#3 Posted : Friday, May 5, 2017 2:14:42 PM(UTC)
MegaJos
IceStream wrote:
@ MegaJos
I use MS Expressions Blend 4. Used it before in another graphic but that worked, as far as I can remember.
#4 Posted : Friday, May 5, 2017 2:40:22 PM(UTC)
Do you have shadows in your title ??
per https://forums.vmix.com/default.aspx?g=posts&t=7100
