Anyone else witnessing that the XAML-product from Blend loses its flow in vMix?
I've made a smooth movement (a moving picture) in Blend that becomes very choppy when imported into vMix. The only thing that I can think of is that it´s made in VB 4.0 instead of vMix-supported 3.5.
@ MegaJos Which version of MS Blend were you using? My understanding is that some of the newer features (commands??) of Visual Studio 2015 are not supported in vMix as per this post here: https://forums.vmix.com/....aspx?g=posts&t=6445Ice
IceStream wrote:@ MegaJos Which version of MS Blend were you using? My understanding is that some of the newer features (commands??) of Visual Studio 2015 are not supported in vMix as per this post here: https://forums.vmix.com/....aspx?g=posts&t=6445Ice I use MS Expressions Blend 4. Used it before in another graphic but that worked, as far as I can remember.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
