I would like to add a stream input to vMix using API.
It works well with local files: - http://localhost:8088/API/?Function=AddInput&Value=Video|C:\Users\Nemesis\Desktop\small.mp4
However impossible to make it work with my RTSPTCP stream. I Tried: - http://localhost:8088/API/?Function=AddInput&Value=Video|rtsp://localhost:1935/vod/sample -> File Not Found - http://localhost:8088/API/?Function=AddInput&Value=Stream|rtsp://localhost:1935/vod/sample -> Function completed successfully. (But not working) - http://localhost:8088/API/?Function=AddInput&Value=RTSPTCP|rtsp://localhost:1935/vod/sample -> Function completed successfully. (But not working)
I can add this input stream using UI, but really interested about adding it with API
Any idea on this ? Thank you
Is it a stream or a video file? .MP4 is a video file, and not a stream.. so it's very ambigious what you are trying to add as an input.
stigaard wrote:Is it a stream or a video file? .MP4 is a video file, and not a stream.. so it's very ambigious what you are trying to add as an input. Sorry it is misleading, I updated the question.
Hi
with a RTMP Stream, it works ?Function=AddInput&Value=Flash|rtmp://192.168.0.67:1935/play/dwamx
with RTSP the correct syntax should be (as reported by the API after manual input) ?Function=AddInput&Value=Stream|RTSPTCP rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov but it doesn't work, I guess because of the space between the protocol and the address
I tried with ?Function=AddInput&Value=Stream|RTSPTCP%20rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov and ?Function=AddInput&Value=Stream|RTSPTCP|rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov but not good either
Any idea for replacing this space in the querystring? Or shall it be reported as a bug?
Guillaume
DWAM wrote:Hi
Awesome, I will use RTMP as a fallback if needed :) Merci Guillaume
With the new VLC stream we definitely need the API script support. Any News for a correct syntax ?
keep up the good work !
I search everything but I can't add a RTMP VLC source via WebAPI. Message to the dev team please make the "AddInput&Value=VLC|RTMPURL" possible.
Best regards.
