nemesis1203
#1 Posted : Friday, May 5, 2017 12:05:29 AM(UTC)
nemesis1203
I would like to add a stream input to vMix using API.
It works well with local files:
- http://localhost:8088/API/?Function=AddInput&Value=Video|C:\Users\Nemesis\Desktop\small.mp4
However impossible to make it work with my RTSPTCP stream. I Tried:
- http://localhost:8088/API/?Function=AddInput&Value=Video|rtsp://localhost:1935/vod/sample -> File Not Found
- http://localhost:8088/API/?Function=AddInput&Value=Stream|rtsp://localhost:1935/vod/sample -> Function completed successfully. (But not working)
- http://localhost:8088/API/?Function=AddInput&Value=RTSPTCP|rtsp://localhost:1935/vod/sample -> Function completed successfully. (But not working)
I can add this input stream using UI, but really interested about adding it with API
Any idea on this ?
Thank you
stigaard
#2 Posted : Friday, May 5, 2017 3:36:04 AM(UTC)
stigaard
Denmark
Is it a stream or a video file? .MP4 is a video file, and not a stream.. so it's very ambigious what you are trying to add as an input.
nemesis1203
#3 Posted : Friday, May 5, 2017 3:41:28 AM(UTC)
nemesis1203
Sorry it is misleading, I updated the question.
#4 Posted : Friday, May 5, 2017 5:02:34 AM(UTC)
Hi
with a RTMP Stream, it works
?Function=AddInput&Value=Flash|rtmp://192.168.0.67:1935/play/dwamx
with RTSP the correct syntax should be (as reported by the API after manual input)
?Function=AddInput&Value=Stream|RTSPTCP rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov
but it doesn't work, I guess because of the space between the protocol and the address
I tried with
?Function=AddInput&Value=Stream|RTSPTCP%20rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov
and
?Function=AddInput&Value=Stream|RTSPTCP|rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov
but not good either
Any idea for replacing this space in the querystring? Or shall it be reported as a bug?
Guillaume
nemesis1203 on 5/5/2017(UTC)
nemesis1203
#5 Posted : Friday, May 5, 2017 5:48:54 AM(UTC)
nemesis1203
DWAM wrote:
Hi
Awesome, I will use RTMP as a fallback if needed :) Merci Guillaume
Kaf
#6 Posted : Thursday, June 8, 2017 5:12:44 PM(UTC)
Kaf
With the new VLC stream we definitely need the API script support.
Any News for a correct syntax ?
keep up the good work !
Kaf
#7 Posted : Tuesday, August 1, 2017 2:18:02 PM(UTC)
Kaf
I search everything but I can't add a RTMP VLC source via WebAPI.
Message to the dev team please make the "AddInput&Value=VLC|RTMPURL" possible.
Best regards.
Guest (4)
