Automatic timed transitions between cameras?
I would like to create a shortcut or something that would allow Vmix to start with input of Cam 1, then automatically transition to Cam 2 after a preset time, then to Cam 3, then 4 etc up to Cam 8, then cycle back to cam 1. Is this possible? Where would I start?
Current System: 8 BlackMagic Intensity cards One Stop Systems 20 slot PCIe Expansion box I7-4770K Gigabyte X87 GTX670 Win 10.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
Hi
it seems the playlist feature is what you're looking for.
Another solution is to create a script (in vmix 4K or Pro) with the "sleep" command.
It can also be done with vMix UTC...
Hope this helps Guillaume
Joined: 2/14/2016(UTC) Posts: 117  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
I also suggest to use the playlist option of vMix. Setup is very easy, just select all camera's and set the duration of the input visible, the transition and off you go.
Thanks! I'll give it a try.
