pcflyer
#1 Posted : Thursday, May 4, 2017 12:47:07 PM(UTC)
pcflyer
I would like to create a shortcut or something that would allow Vmix to start with input of Cam 1, then automatically transition to Cam 2 after a preset time, then to Cam 3, then 4 etc up to Cam 8, then cycle back to cam 1. Is this possible? Where would I start?
Current System:
8 BlackMagic Intensity cards
One Stop Systems 20 slot PCIe Expansion box
I7-4770K
Gigabyte X87
GTX670
Win 10.
#2 Posted : Thursday, May 4, 2017 1:00:11 PM(UTC)
Hi
it seems the playlist feature is what you're looking for.
Another solution is to create a script (in vmix 4K or Pro) with the "sleep" command.
It can also be done with vMix UTC...
Hope this helps
Guillaume
Mari
#3 Posted : Thursday, May 4, 2017 1:12:42 PM(UTC)
Mari
Netherlands
I also suggest to use the playlist option of vMix. Setup is very easy, just select all camera's and set the duration of the input visible, the transition and off you go.
pcflyer
#4 Posted : Thursday, May 4, 2017 1:23:38 PM(UTC)
pcflyer
Thanks! I'll give it a try.
pcflyer
#5 Posted : Thursday, May 4, 2017 5:19:50 PM(UTC)
pcflyer
That worked, Thank you!
