pagu
#1 Posted : Wednesday, May 3, 2017 7:26:20 AM(UTC)
pagu
i need to create a rtsp server as the normal ip camera, the streaming hosting need a rtsp stream by HTTP/RTSP.
how i can create this?
thank you in advance
#2 Posted : Wednesday, May 3, 2017 7:28:52 AM(UTC)
Hi Pagu
not very clear. I understand you need to deliver your stream with the RTSP protocol, right?
You can do this with VLC or FFMPEG. You will also need to handle port forwarding on your router.
Guillaume
#3 Posted : Wednesday, May 3, 2017 7:49:51 AM(UTC)
Another solution is to use a streaming server in the cloud which can do the RTMP to RTSP protocol switch, like Wowza for example
pagu
#4 Posted : Wednesday, May 3, 2017 10:10:07 AM(UTC)
pagu
DWAM wrote:
Hi Pagu
Guillaume
Yes dear Dwam, i need to deliver by rtsp ad the streaming provier, they not support a rtmp flux.
this service work very well and it's cheaper for 24h/24h.
you know others users that use the server for generate rtsp?
thank you
#5 Posted : Wednesday, May 3, 2017 11:45:55 AM(UTC)
It's quite strange as RTMP is the most common protocol for ingest on streaming platforms even for 24/7 broadcast.
RTMP is a "push" protocol: you push your feed to the server for delivery
RTSP is a "pull" protocol: the server needs to access your RTSP device to request the feed
That's why RTSP is most commonly used for inputs and RTMP for output.
It seems that this provider is specialized in single IP cameras or webcams ingestion, like security cameras for example. It doesn't seem to be a good choice when working with vMix, because you are most likely to need to pay extra somewhere for RTMP 2 RTSP conversion, unless you do it yourself with VLC or FFMPEG as I suggested before.
Apart from this, I am not aware of a potential free server/service that you could use for this.
Maybe some other guys have an alternate solution?
Guillaume
mjgraves on 5/22/2017(UTC)
#6 Posted : Thursday, May 4, 2017 4:36:46 AM(UTC)
From PM
Hello Dwam,
this is the service: https://ipcamlive.com/howdoesitwork
What do you think about this service? it's very cheapeer and vork very well, but the problem it's rtsp
Hi Pagu
it's exactly what I suspected: a service for ip cameras
My opinion: don't go there, it is not optimized for vMix use technically speaking.
You will get a better service from free platform like YouTube for example. If you don't want your stream to be public, just make it "confidential" or "private"
$25/month is not particularly cheap. Check inacdn.com for example: it's Pay As You Go - 25 $ / TB with RTMP support.
It's up to you... ;o)
Maybe some others guys around here have different feeling/opinion about this?
Guillaume
pagu
#7 Posted : Friday, May 5, 2017 4:06:18 AM(UTC)
pagu
Hello dear Guillaume,
yes i have a pubblic website that i show the webcam of the city, and should be a internal streaming.
yes good service, but they have a problem with contacts, i will contact by social. you know other cheap service?
they are welcome :)
Very thanks Guillaume
#8 Posted : Friday, May 5, 2017 4:22:04 AM(UTC)
I don't understand this. What do you mean?
Public? Opened for everybody or reserved for a public (governemental/administration) service?
Internal streaming? to be streamed only on a private network, e.g. intranet, not the internet?
pagu
#9 Posted : Sunday, May 21, 2017 5:49:27 AM(UTC)
pagu
Hello Guillaume,
Excuse this long time, but i was busy for work and study.
yes the camera streaming it's public for everybody, i mean that the people can watch stream without limitation.
i think that for me it's possible use youtube too, but there i get problems about delay (minuts).
my upload bitrate it's about 1mb and in control panel settings i selected 480p.
vmix streaming settings is:
input size 854*480
frame r:29,97
settings FMLE quality:
bitrate 1000
encode size 854*480, audio 96
profile: baseline
level: 3.1
keyframe: 2 seconds
auto adjust: none
audio: acc, master
Any idea?
Thank you
Al.
#10 Posted : Sunday, May 21, 2017 10:41:19 AM(UTC)
Ciao Pagu
Any idea?
What about?
I don't think you'll have minutes delay for a 480p stream on YouTube, but 15 seconds at most
I told you already you can use VLC or FFMPEG for RTSP streaming. I can add there are more and more external encoder boxes on the market which provide RTSP encoding too. But they have a cost, and I still consider RTMP being a better option.
One last thing, in Europe we are supposed to work at 25 fps, not 29.97. Not a big deal but I never understand why standards are not respected.
So I don't know what you're asking for right now ! Please be more specific if you want specific answers.
Cordiali saluti
Guillaume
h2video.nl
#11 Posted : Sunday, May 21, 2017 11:34:08 AM(UTC)
h2video.nl
i use a yuan streambox for this. you output from vmix and the streambox will take the sognal in by sdi or hdmi or whatever you output to and then you can choose the protocol, rtmp rtsp etc etc. woth a vlc client you can the pickup the stream.
i hook it up to a wifi i take along and people on the same network can pick it up. i can also use it to stream to whatever, but vmix can do that internally.
this thing is small, sturdy and not expensive. i have it in my gear all the time, so i can set up a local stream in a snap.
maybe this is what you can use? there are a number of software sollutions but they cost something as well and you have to run it on something. i don t like to have other programs running on my vmix machine, so i opt for seperate machines to do the trick.
yoan sc600 or something, i ll look it up if you are interested.
stefan
h2video.nl
#12 Posted : Sunday, May 21, 2017 11:37:22 AM(UTC)
h2video.nl
http://www.yuan.com.tw/p...ucts/streaming/sc601.htm
there is a whole new line out as well.
stefan
Guest (4)
