atomgun
#1 Posted : Sunday, April 30, 2017 6:44:48 AM(UTC)
atomgun
I use multicorder funtion record about 1 hour and 44 minutes but output file duration is about 4 minutes.
and File(MP4 indexed) can open normally.
What is problem and how to fix or prevent it happen again.
Environment:
- vmix Version: 19.0.0.43 x64
- window 10 x64
- CPU ryzen 1700x
- GPU AMD redeon R9 280
- Capture card Blackmagic DeckLink Mini Recorder
- Muticorder FFMPEG
--- codec MP4 x264 ACC
--- format MP4 (indexed)
Log file
25-Apr-17 10:14:10, Version: 19.0.0.43 x64
25-Apr-17 10:14:10, Size: 1920x1080
25-Apr-17 10:14:10, System: PAL 50i
25-Apr-17 10:14:10, Codec: FFMPEG
25-Apr-17 10:14:10, Format: UYVY 16 1498831189
25-Apr-17 10:14:10, AudioDevice: RawAudio
25-Apr-17 10:14:10, AudioFormat: Default
25-Apr-17 10:14:10, AudioDelay: 0
25-Apr-17 10:14:10, RestartInterval: 60
25-Apr-17 10:14:10, Buffers: 25
25-Apr-17 10:14:10, FFMPEGCommand: -pix_fmt yuv420p -vcodec libx264 -preset:v veryfast -profile:v main -b:v 6M -acodec libfaac -b:a 128k -f mp4
25-Apr-17 10:14:10, StartRecording
25-Apr-17 11:58:40, StopRecording
25-Apr-17 11:58:40, Duration: 00:04:04
25-Apr-17 11:58:40, Frames: 6097
25-Apr-17 11:58:40, DroppedFrames: 0
25-Apr-17 11:58:40, DueToSourceFrameRate: 0
25-Apr-17 11:58:40, DueToHardDiskOrCPU: 0
25-Apr-17 11:58:40, DroppedSamples: 0
25-Apr-17 11:58:40, MissedSamples: 0
25-Apr-17 11:58:40, SyncedSamples: 0
25-Apr-17 11:58:40, AudioOffset: 0
25-Apr-17 11:58:40, AudioDelay: 0
25-Apr-17 11:58:40, AudioEngine
25-Apr-17 11:58:40, Running: True
25-Apr-17 11:58:40, SampleRate: 48000hz 16 Bit
25-Apr-17 11:58:40, MixingErrors: 0
25-Apr-17 11:58:40, Streams
25-Apr-17 11:58:40, Mixer
25-Apr-17 11:58:40, Samples: 333596
25-Apr-17 11:58:40, Dropped: Read 224 Write 0
25-Apr-17 11:58:40, Latency: 0 ms
25-Apr-17 11:58:40, Errors: 0
25-Apr-17 11:58:40, Headphones
25-Apr-17 11:58:40, Samples: 333121
25-Apr-17 11:58:40, Dropped: Read 292 Write 183
25-Apr-17 11:58:40, Latency: 50 ms
25-Apr-17 11:58:40, AV
25-Apr-17 11:58:40, Samples: 301242
25-Apr-17 11:58:40, Dropped: Read 2551 Write 0
25-Apr-17 11:58:40, Latency: 100 ms
25-Apr-17 11:58:40, TargetLatency: 120 ms
25-Apr-17 11:58:40, Resampled: 55260/580
Mathijs
#2 Posted : Sunday, April 30, 2017 8:35:07 PM(UTC)
Mathijs
Was thanked: 81 time(s) in 72 post(s)
First backup the file.
In your startmenu, in the vMix folder, you find "vMix video tools".
Let that process your file as it might fix the index and you have a big chance it will be fully there.
atomgun
#3 Posted : Tuesday, May 2, 2017 1:59:11 AM(UTC)
atomgun
I've tried this but it didn't work.
I think, raw source file already indexed.
more information about this output file
Length : 00:04:03
Frame width : 1920
Frame height: 1080
Date modified: 25-Apr-17 11:58
Date created: 25-Apr-17 10:14
Framerate: 25 frames/second
Data rate: 6016kbps
Total bitrate: 6144kbps
[img][/img]
atomgun attached the following image(s):
Mathijs
#4 Posted : Tuesday, May 2, 2017 4:42:25 AM(UTC)
Mathijs
Well then I don't know. I never use mp4 as multicorder format, so did not see this before.
I had things like this happen, but in those cases the filesize was much bigger than a few minutes, and it was fixable with re-indexing.
In your case the filesize seems right for 4 minutes.
