atomgun
#1 Posted : Sunday, April 30, 2017 6:44:48 AM(UTC)
atomgun
I use multicorder funtion record about 1 hour and 44 minutes but output file duration is about 4 minutes.
and File(MP4 indexed) can open normally.
What is problem and how to fix or prevent it happen again.
Environment:
- vmix Version: 19.0.0.43 x64
- window 10 x64
- CPU ryzen 1700x
- GPU AMD redeon R9 280
- Capture card Blackmagic DeckLink Mini Recorder
- Muticorder FFMPEG
--- codec MP4 x264 ACC
--- format MP4 (indexed)
Log file
25-Apr-17 10:14:10, Version: 19.0.0.43 x64
25-Apr-17 10:14:10, Size: 1920x1080
25-Apr-17 10:14:10, System: PAL 50i
25-Apr-17 10:14:10, Codec: FFMPEG
25-Apr-17 10:14:10, Format: UYVY 16 1498831189
25-Apr-17 10:14:10, AudioDevice: RawAudio
25-Apr-17 10:14:10, AudioFormat: Default
25-Apr-17 10:14:10, AudioDelay: 0
25-Apr-17 10:14:10, RestartInterval: 60
25-Apr-17 10:14:10, Buffers: 25
25-Apr-17 10:14:10, FFMPEGCommand: -pix_fmt yuv420p -vcodec libx264 -preset:v veryfast -profile:v main -b:v 6M -acodec libfaac -b:a 128k -f mp4
25-Apr-17 10:14:10, StartRecording
25-Apr-17 11:58:40, StopRecording
25-Apr-17 11:58:40, Duration: 00:04:04
25-Apr-17 11:58:40, Frames: 6097
25-Apr-17 11:58:40, DroppedFrames: 0
25-Apr-17 11:58:40, DueToSourceFrameRate: 0
25-Apr-17 11:58:40, DueToHardDiskOrCPU: 0
25-Apr-17 11:58:40, DroppedSamples: 0
25-Apr-17 11:58:40, MissedSamples: 0
25-Apr-17 11:58:40, SyncedSamples: 0
25-Apr-17 11:58:40, AudioOffset: 0
25-Apr-17 11:58:40, AudioDelay: 0
25-Apr-17 11:58:40, AudioEngine
25-Apr-17 11:58:40, Running: True
25-Apr-17 11:58:40, SampleRate: 48000hz 16 Bit
25-Apr-17 11:58:40, MixingErrors: 0
25-Apr-17 11:58:40, Streams
25-Apr-17 11:58:40, Mixer
25-Apr-17 11:58:40, Samples: 333596
25-Apr-17 11:58:40, Dropped: Read 224 Write 0
25-Apr-17 11:58:40, Latency: 0 ms
25-Apr-17 11:58:40, Errors: 0
25-Apr-17 11:58:40, Headphones
25-Apr-17 11:58:40, Samples: 333121
25-Apr-17 11:58:40, Dropped: Read 292 Write 183
25-Apr-17 11:58:40, Latency: 50 ms
25-Apr-17 11:58:40, AV
25-Apr-17 11:58:40, Samples: 301242
25-Apr-17 11:58:40, Dropped: Read 2551 Write 0
25-Apr-17 11:58:40, Latency: 100 ms
25-Apr-17 11:58:40, TargetLatency: 120 ms
25-Apr-17 11:58:40, Resampled: 55260/580
Mathijs
#2 Posted : Sunday, April 30, 2017 8:35:07 PM(UTC)
Mathijs
First backup the file.
In your startmenu, in the vMix folder, you find "vMix video tools".
Let that process your file as it might fix the index and you have a big chance it will be fully there.
atomgun
#3 Posted : Tuesday, May 2, 2017 1:59:11 AM(UTC)
atomgun
I've tried this but it didn't work.
I think, raw source file already indexed.
more information about this output file
Length : 00:04:03
Frame width : 1920
Frame height: 1080
Date modified: 25-Apr-17 11:58
Date created: 25-Apr-17 10:14
Framerate: 25 frames/second
Data rate: 6016kbps
Total bitrate: 6144kbps
[img][/img]
atomgun attached the following image(s):
Mathijs
#4 Posted : Tuesday, May 2, 2017 4:42:25 AM(UTC)
Mathijs
Well then I don't know. I never use mp4 as multicorder format, so did not see this before.
I had things like this happen, but in those cases the filesize was much bigger than a few minutes, and it was fixable with re-indexing.
In your case the filesize seems right for 4 minutes.
