Feature Requests
Control from a distance!!!!!
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
It would be great to control a Vmix machine through WebRTC! Having multiple people controlling deferent things from far away would be great!
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
Thanks for sharing our demo video using APC Mini - Midi controller remotely.
Very good solution, but I was think something like the Livestream Studio solution
@ alexandrelinhares1
I'm not really familiar with the current "LiveStream Studio", can you elaborate a little more as to how it works and how you envisage a similar or better workflow with vMix?
[img][/img] alexandrelinhares1 attached the following image(s):  Captura de Tela 2017-04-27 às 07.37.03.png (1,325kb) downloaded 13 time(s).You cannot view/download attachments. Try to login or register.
It makes a certain amount of sense that WebRTC could be used to effect an RDP or TeamViewer-like functionality. Most especially given that you have the data channel as a means to pass user activity back & forth.
@ alexandrelinhares1 Well that image from the website doesn't really give too much detail as to what is actually possible remotely aside from controlling the "Graphics Module" through "DropBox", which has already been possible in vMix for a couple of years already. Check out Tom Sinclair's "Streaming Idiots" show from 2015: vMix also provides a greater degree of "control" of the actual switcher over the LAN via the "WebController", which I am sure you already know but I assume you are looking for an expansion of that functionality to be available anywhere in the world over the WEB (as is more or less demonstrated in the video from my first post above). So, unless I am mistaken, what more functionality or workflow improvements are you looking for? Ice
IceStream wrote:@ alexandrelinhares1
I presume that the existing web controller mechanism is intended for use on the local LAN. What WebRTC could add would be very much like vMix Call, the ability to establish a secure connection from afar. WebRTC provides is a secure connection by default, that handles NAT traversal. It's an alternative to a VPN. The data channel mechanism has already been used to implement a distributed, peer-to-peer CDN. I personally have used it to control a jumping drone via the web from half-way around the planet.
Feature Requests
