alexandrelinhares1
#1 Posted : Wednesday, April 26, 2017 4:24:06 PM(UTC)
alexandrelinhares1
It would be great to control a Vmix machine through WebRTC! Having multiple people controlling deferent things from far away would be great!
#2 Posted : Wednesday, April 26, 2017 6:25:56 PM(UTC)
@ alexandrelinhares1
Check out this Video here:
As described in this thread here:
https://forums.vmix.com/....aspx?g=posts&t=9598
corporatejames on 4/26/2017(UTC)
corporatejames
#3 Posted : Wednesday, April 26, 2017 10:12:16 PM(UTC)
corporatejames
Thanks for sharing our demo video using APC Mini - Midi controller remotely.
alexandrelinhares1
#4 Posted : Thursday, April 27, 2017 12:49:36 PM(UTC)
alexandrelinhares1
Very good solution, but I was think something like the Livestream Studio solution
#5 Posted : Thursday, April 27, 2017 4:24:31 PM(UTC)
I'm not really familiar with the current "LiveStream Studio", can you elaborate a little more as to how it works and how you envisage a similar or better workflow with vMix?
alexandrelinhares1
#6 Posted : Friday, April 28, 2017 6:39:35 AM(UTC)
alexandrelinhares1
[img][/img]
alexandrelinhares1 attached the following image(s):
Captura de Tela 2017-04-27 às 07.37.03.png (1,325kb) downloaded 13 time(s).
mjgraves
#7 Posted : Friday, April 28, 2017 8:42:30 AM(UTC)
mjgraves
It makes a certain amount of sense that WebRTC could be used to effect an RDP or TeamViewer-like functionality. Most especially given that you have the data channel as a means to pass user activity back & forth.
#8 Posted : Friday, April 28, 2017 9:47:58 AM(UTC)
Well that image from the website doesn't really give too much detail as to what is actually possible remotely aside from controlling the "Graphics Module" through "DropBox", which has already been possible in vMix for a couple of years already.
Check out Tom Sinclair's "Streaming Idiots" show from 2015:
vMix also provides a greater degree of "control" of the actual switcher over the LAN via the "WebController", which I am sure you already know but I assume you are looking for an expansion of that functionality to be available anywhere in the world over the WEB (as is more or less demonstrated in the video from my first post above).
So, unless I am mistaken, what more functionality or workflow improvements are you looking for?
mjgraves
#9 Posted : Friday, April 28, 2017 10:24:56 AM(UTC)
mjgraves
I presume that the existing web controller mechanism is intended for use on the local LAN. What WebRTC could add would be very much like vMix Call, the ability to establish a secure connection from afar.
WebRTC provides is a secure connection by default, that handles NAT traversal. It's an alternative to a VPN.
The data channel mechanism has already been used to implement a distributed, peer-to-peer CDN. I personally have used it to control a jumping drone via the web from half-way around the planet.
