royalones
#1 Posted : Thursday, February 3, 2011 5:52:16 PM(UTC)
royalones
I created another input using a DVD. I also have two other capture devises (web cams). I am getting the audio from the web cams, but I still can not hear any audio coming from the DVD (internal player).
#2 Posted : Thursday, February 3, 2011 10:16:07 PM(UTC)
Was thanked: 4749 time(s) in 1632 post(s)
If you are using Windows 7, it doesn't include a DVD Audio decoder by default.
(Only one for Windows Media Player).
To fix this download AC3Filter from: http://ac3filter.net/projects/ac3filter/releases
royalones on 2/4/2011(UTC)
royalones
#3 Posted : Friday, February 4, 2011 10:57:13 AM(UTC)
royalones
Well, it seems to have fixed not being able to hear the input, but I still do not seem to be capturing the audio from any of the video (dvd, mpeg) sources - other than the web cams. Still confused.
#4 Posted : Friday, February 4, 2011 10:59:16 AM(UTC)
In the vMix settings under Decoders set MPEG Audio to AC3Filter, this should fix the audio from DVD sources.
royalones
#5 Posted : Friday, February 4, 2011 11:33:52 AM(UTC)
royalones
That has already been done. I can still hear all audio sources in the mixer, but I still cannot capture the audio - specifically from any dvd or video file. On the main settings > Audio > -- which renderer should I be using? I have 5 options that show:
1 - Speakers
2 - Cyberlink Audio
3 - Default Direct Sound
4 - Default WaveOut
5 - DirectSound: Speakers
royalones
#6 Posted : Friday, February 4, 2011 11:53:13 AM(UTC)
royalones
Don't know if this matters (I think it may, though), but under the audio options for the record settings, my webcams are the only options. There is not sound card or wave option.
#7 Posted : Friday, February 4, 2011 10:29:10 PM(UTC)
If there is no Wave or Stereo Mix option under the recording settings than your sound card may not support recording in that way.
You can double check this from the Control Panel:
1. Open Control Panel.
2. Go to Sound.
3. Under the Recording tab right click anywhere and click "Show Disabled Devices"
There should now be an option for Wave or "Stereo Mix" you can enable and use in vMix.
