system stability
I am testing on Vmix MB- X58A-UD2R 120 SSD Intensity pro x2 INtensity shuttle ( with NEC card ) 920 x2
I have another 2 intensity card
Anyone have the stability issue
Because something it go blue screen and restart
What is the problem How to make the system more stabil
Is it cost by USB device ( plese consult)
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
If you are getting a blue screen it means one of two things:
1. Faulty drivers, please update your drivers for all hardware to the latest version. 2. Faulty hardware, this is harder to solve, but you can remove hardware like the intensity shuttle until you no longer have a blue screen.
Martin vMix
THanks I will try and see
if I am using usb cam like web cam will it load up too much ( any limit )
and Intensity pro if I add 4 card will it be over load
Just want to know anyone try it before
