timothychew
#1 Posted : Wednesday, March 6, 2013 6:47:44 PM(UTC)
timothychew
system stability
I am testing on Vmix
MB- X58A-UD2R
120 SSD
Intensity pro x2
INtensity shuttle ( with NEC card )
920 x2
I have another 2 intensity card
Anyone have the stability issue
Because something it go blue screen
and restart
What is the problem
How to make the system more stabil
Is it cost by USB device ( plese consult)
#2 Posted : Wednesday, March 6, 2013 10:13:42 PM(UTC)
Was thanked: 4736 time(s) in 1625 post(s)
If you are getting a blue screen it means one of two things:
1. Faulty drivers, please update your drivers for all hardware to the latest version.
2. Faulty hardware, this is harder to solve, but you can remove hardware like the intensity shuttle until you no longer have a blue screen.
timothychew
#3 Posted : Thursday, March 7, 2013 3:03:02 AM(UTC)
timothychew
THanks I will try and see
if I am using usb cam like web cam
will it load up too much ( any limit )
and Intensity pro
if I add 4 card will it be over load
Just want to know anyone try it before
