Stinger transition with audio
Joined: 12/20/2016(UTC) Posts: 190   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I'd like to build a stinger transition with audio. Do you think it's possible? I know the stinger is an image sequence so it could be impossible to assign an audio. What do you think about? (I know that DWAM will say: "use API" eheheheheh but as he knows I don't know API programming language). Do you think there is a different way?
"use triggers" eheheheheh
;o)
[Edit] Actually no, triggering audio won't work on a stinger.
What you can do is set the audiofile as a multiview source for your image sequence input. This works, I just tried.
eheheheheh
 2 users thanked DWAM for this useful post.
DWAM wrote:"use triggers" Or use Multi-view to attach an audio input :-) Multi-view meaning - for the image sequence - open general settings - and then go to Multi view and attach the audio input you want. EDIT: DWAM just wrote the same answer :D :D :D
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ spino
The "Stinger" can be any video source (i.e. with audio), although it is smoother (consistent) when using an image sequence. The trick to adding audio to an Image Sequence is to use the "Multiview" feature and add the audio as an oveverlay. Hope that helps some.
EDIT: you gotta be quick if you want to beat Guillaume to the punch! lol I had to take a call before completing my post, by the time I got back to it and posted, I was already trumped...
Yes Jens, I guess we were writing at the same time!
Trigger method doesn't work for a stinger as it is not considered as a "regular" input, thus "OnTransitionIn" or "OnOverlayIn" conditions are not effective.
Thank you guys, with multiview it works.
Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav
DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav As soon as I can I try. Thank you.
You have been a member since:: 6/12/2015(UTC) Posts: 76 Location: Finland
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
So if image001.png is the first image set the sound to be image001.png.wav This works
 4 users thanked -TA_ for this useful post.
-TA_ wrote:DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav This works Not here. I loaded both mp3 and wav files renamed with the first image png but it didn't work. Please, can you give me the steps you made? Thank you.
spino wrote:-TA_ wrote:DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav This works Not here. I loaded both mp3 and wav files renamed with the first image png but it didn't work. Please, can you give me the steps you made? Thank you. I don't remember steps but in the same folder I have png's and mp3. First png is xxx.png and sound file is xxx.png.mp3
-TA_ wrote:spino wrote:-TA_ wrote:DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav This works Not here. I loaded both mp3 and wav files renamed with the first image png but it didn't work. Please, can you give me the steps you made? Thank you. I don't remember steps but in the same folder I have png's and mp3. First png is xxx.png and sound file is xxx.png.mp3 I did the same but it doesn't work. I'll try again.
spino wrote:-TA_ wrote:spino wrote:-TA_ wrote:DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav This works Not here. I loaded both mp3 and wav files renamed with the first image png but it didn't work. Please, can you give me the steps you made? Thank you. I don't remember steps but in the same folder I have png's and mp3. First png is xxx.png and sound file is xxx.png.mp3 I did the same but it doesn't work. I'll try again. OK, I found the problem. The audio file must be present in the same folder of the image sequence BEFORE to add a stinger. If you add the stinger and after that you add the music to the folder, it doesn't work. Actually there is a problem: if you have a music longer than the image sequence, it goes on even after the transition (with multiview method this not happens). So, I think that the better method to add music to a stinger is the multiview.
Normally when you create a stinger, the audio is chosen on purpose and has the same duration as the sequence so it doesn't matter, but yes the multiview solution solves this in case you use test material. However it also cuts audio abruptly when the sequence ends, so it is not nice and smooth as stinger should be.
DWAM wrote:Normally when you create a stinger, the audio is chosen on purpose and has the same duration as the sequence so it doesn't matter, but yes the multiview solution solves this in case you use test material. However it also cuts audio abruptly when the sequence ends, so it is not nice and smooth as stinger should be. You're absolutely right but I'm making just some test to know Vmix in detail.
Originally Posted by: spino  spino wrote:-TA_ wrote:spino wrote:-TA_ wrote:DWAM wrote:Just found this in an old topic. From Martin himself... Not tested Quote:There is some undocumented support for sounds with image sequences that I didn't have time to add to the UI in 16. If you create a wav or mp3 file with the same name as the first image it will be loaded and used automatically.
So if image001.png is the first image set the sound to be image001.png.wav This works Not here. I loaded both mp3 and wav files renamed with the first image png but it didn't work. Please, can you give me the steps you made? Thank you. I don't remember steps but in the same folder I have png's and mp3. First png is xxx.png and sound file is xxx.png.mp3 I did the same but it doesn't work. I'll try again. OK, I found the problem. The audio file must be present in the same folder of the image sequence BEFORE to add a stinger. If you add the stinger and after that you add the music to the folder, it doesn't work. Actually there is a problem: if you have a music longer than the image sequence, it goes on even after the transition (with multiview method this not happens). So, I think that the better method to add music to a stinger is the multiview. I have found the Multiview method to not work well for me. A simple swoosh WAV that is timed with the stinger starts in the middle of the audio and at other times does not play at all. Using the file renaming method words perfectly. It is also useful when playing a swoosh for the audio to extend past the stinger transition (which is a "feature" of using this method).
Originally Posted by: 郭子涵  you can use “.Mov”! What are you referring to? Thank you.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: bluesgeek  Originally Posted by: 郭子涵  you can use “.Mov”! What are you referring to? Thank you. a MOV video file with audio included ! Also having an audio file in your image sequence is an option (see help files)
