Problem with external - Intensity PRO
Hello, I get random problem with External output. Im using 1080p59 with external outupt to Intensity PRO and I get this message https://gyazo.com/eb7217b0e05c2f59d94a4544b32a3a81And external output ended. Before this message I noticed drop frames Anyone help? Thanx
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Welcome to the vMix Support Forum. We are here to help! But we need more information about your system.
CPU GPU RAM Drives Recording format vMix Version #
What is the overall resolution in vMix set for? How long does it record before you get this message? Are you live streaming also? Have you configured the External Renderer for the BMD Intensity Pro? Is it configured for 1080p59.97?
Thanks.
- Tom
I5 GEFORCE 1060 8GB RAM SSD 256 SSD 1GB
LATEST VERSION, ACTUALLY DOWNLOADED 1920x1080 60p Its not a record its External to hdmi output from intensity pro No streaming Yes, in vmix Yes is it
This message a i I get randomly, sometimes in 2 min, sometimes after 3 hours. And luckly after 7 hours.
Its 59.97, not exatly 60.
Should be 29.97 or 59.94. Not 59.97!
Yes, sorry im writing from bed in Czech rep. Is night :)
A couple of thing to check...
What is your Render Time when streaming & using External Output? What is your CPU Usage when streaming & using External Output? What are your External stats when streaming & using External Output? That's the little "i" next to the External button.
You might try a lower frame rate than 59.94p. Maybe 29.97p or 59.94i. You might try a lower resolution. Make sure your Stream settings are using the Hardware Encoder.
BTW, vMix works best with i7 for 1080p.
- Tom
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I am using this for graphics, why are you doing 1080/59, put 1080/25 and you probably want have any problems Second thing is that your PC is not so good for doing this, stream and external will not go smooth, I have the same, you need better CPU
