tripsi
#1 Posted : Tuesday, April 18, 2017 5:04:23 PM(UTC)
tripsi
I get random problem with External output. Im using 1080p59 with external outupt to Intensity PRO and I get this message
https://gyazo.com/eb7217b0e05c2f59d94a4544b32a3a81
And external output ended. Before this message I noticed drop frames
Anyone help?
Thanx
sinc747
#2 Posted : Tuesday, April 18, 2017 5:39:40 PM(UTC)
sinc747
Welcome to the vMix Support Forum. We are here to help! But we need more information about your system.
CPU
GPU
RAM
Drives
Recording format
vMix Version #
What is the overall resolution in vMix set for?
How long does it record before you get this message?
Are you live streaming also?
Have you configured the External Renderer for the BMD Intensity Pro? Is it configured for 1080p59.97?
Thanks.
- Tom
tripsi
#3 Posted : Tuesday, April 18, 2017 6:31:34 PM(UTC)
tripsi
I5
GEFORCE 1060
8GB RAM
SSD 256
SSD 1GB
LATEST VERSION, ACTUALLY DOWNLOADED
1920x1080 60p
Its not a record its External to hdmi output from intensity pro
No streaming
Yes, in vmix
Yes is it
This message a i I get randomly, sometimes in 2 min, sometimes after 3 hours. And luckly after 7 hours.
tripsi
#4 Posted : Tuesday, April 18, 2017 6:33:29 PM(UTC)
tripsi
Its 59.97, not exatly 60.
#5 Posted : Tuesday, April 18, 2017 6:45:20 PM(UTC)
Should be 29.97 or 59.94. Not 59.97!
tripsi
#6 Posted : Tuesday, April 18, 2017 7:05:38 PM(UTC)
tripsi
Yes, sorry im writing from bed in Czech rep. Is night :)
sinc747
#7 Posted : Wednesday, April 19, 2017 4:07:29 PM(UTC)
sinc747
A couple of thing to check...
What is your Render Time when streaming & using External Output?
What is your CPU Usage when streaming & using External Output?
What are your External stats when streaming & using External Output? That's the little "i" next to the External button.
You might try a lower frame rate than 59.94p. Maybe 29.97p or 59.94i.
You might try a lower resolution.
Make sure your Stream settings are using the Hardware Encoder.
BTW, vMix works best with i7 for 1080p.
- Tom
Siroki
#8 Posted : Thursday, April 20, 2017 3:52:34 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
I am using this for graphics, why are you doing 1080/59, put 1080/25 and you probably want have any problems
Second thing is that your PC is not so good for doing this, stream and external will not go smooth, I have the same, you need better CPU
Guest (5)
