NDI
Tested tablet to run NDI Monitor
Joined: 8/21/2012(UTC) Posts: 194  Location: Cordoba - Argentina Thanks: 50 times Was thanked: 6 time(s) in 6 post(s)
Hi to everyone! I want to know if somebody here has been tested a W10 tablet to run NDI monitor. I want to provide a low resolution output in a 7 inches device, so i think a tablet will be a cheap option. Thanks
Hi
It might work if your tablet's CPU meets NDI requirements and if your Wifi is powerful enough. However I doubt this is a very convenient solution as NDI requires high resources.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ guztavo
Another option is to use vMixCall if you have internet access.
Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
I have used an atom based desktop many times before https://www.newegg.com/P...aspx?Item=9SIA7HN59X1733 this one in particular. While it is no tablet for your use case the hardware is no different than the low end tablets that exist today with Windows 10. I simply prefer this because it has an Ethernet port. A suggestion would be to get a tablet with an that has the capability of running USB in as well as power at the same time - and get Ethernet to connect. While Wi-Fi may work, you can find issues with Wi-Fi in some of the low end tablets.
NDI
