guztavo
#1 Posted : 8 years ago
guztavo
Hi to everyone!
I want to know if somebody here has been tested a W10 tablet to run NDI monitor.
I want to provide a low resolution output in a 7 inches device, so i think a tablet will be a cheap option.
#2 Posted : 8 years ago
Was thanked: 794 time(s) in 589 post(s)
Hi
It might work if your tablet's CPU meets NDI requirements and if your Wifi is powerful enough.
However I doubt this is a very convenient solution as NDI requires high resources.
#3 Posted : 8 years ago
Was thanked: 509 time(s) in 478 post(s)
@ guztavo
Another option is to use vMixCall if you have internet access.
#4 Posted : 8 years ago
I think the cheapest and most reliable way to do that is to use a field monitor
https://www.amazon.com/s...k?keywords=field+monitor
csepi74
#5 Posted : 8 years ago
csepi74
I use this one for monitornig and testing the NDI output of my Vmix PC.
http://www.gearbest.com/...KYcHMmqV02kkEaAuCl8P8HAQ
Intel Z8300, 2GB RAM, 32-bit Windows 10
The Newtek NDI monitor works on this hardware.
KJ4AWR
#6 Posted : 8 years ago
KJ4AWR
I have used an atom based desktop many times before
https://www.newegg.com/P...aspx?Item=9SIA7HN59X1733
this one in particular.
While it is no tablet for your use case the hardware is no different than the low end tablets that exist today with Windows 10.
I simply prefer this because it has an Ethernet port. A suggestion would be to get a tablet with an that has the capability of running USB in as well as power at the same time - and get Ethernet to connect. While Wi-Fi may work, you can find issues with Wi-Fi in some of the low end tablets.
