dasmedienatelier
#1 Posted : Tuesday, April 18, 2017 8:17:49 AM(UTC)
dasmedienatelier
in the changelog of vMix 19.0.0.42 it says:
"* Fixed DataSource Format field reverting to {0} in edit window"
That's great to hear. But when I enter {0:00} or any other number format string, still nothing happens (i.e. should be zero-padded)?
Knut
#2 Posted : Tuesday, April 18, 2017 10:54:15 AM(UTC)
Because its string formatting based , not numeric as far as i can tell
#3 Posted : Tuesday, April 18, 2017 11:27:05 AM(UTC)
Correct, it is a string format for prepending/appending text to an existing field.
You can use formatting in an excel spreadsheet to format numbers for use by vMix Data Sources.
dasmedienatelier
#4 Posted : Wednesday, April 19, 2017 3:41:47 AM(UTC)
dasmedienatelier
Hi Martin,
thanks for replying.
But bare with me: if I use formatting outside of vMix and put "00" (even whith quotes) in a csv file it shows up as '0' inside vMix when connected via datasources manager. How do I zero pad then?
jjlittle
#5 Posted : Monday, February 11, 2019 6:12:49 AM(UTC)
jjlittle
Canada
Have you ever found a solution to this? I have the exact same problem. I need 2 decimal places to show, and it always drops trailing 0's no matter what format string or original strings I have provided in the CSV so far. I also have an issue with a leading '+' being dropped.
I generate the CSV, so I could generate a different file type if it will help.
Data Examples: +5.01 in the CSV file results in 5.01 in the data source... -5.01 in the CSV results in -5.01 in the data source... 1:10.30 in the CSV file results in 1:10.3 in the data source.
